what size are you running for runners on a turbo maifold?
i am making my own manifold for a h22 swap eg, i have all the items i need but he pipe. i am going to runa schedule 10 ss pipe, but i am unsure of the size. what diameter are you using? ia m running a premium bmc race flange for an h22. thanks ahead.
Modified by meanEG at 1:48 PM 9/1/2005
I was just going off some stuff in my head. I remember it being a bit more than the general figure, just not knowing by how much
wowo i am so confused, people use many differnt things. why not use same material as the collectors?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">I use 1.75" o.d. .065" wall tubing and when shaped to match the port it fits perfect.</TD></TR></TABLE>
Not me .I use 1 3/4 16 ga. and I hit the end of the tube with a rubber mallet then it fits the port perfect.
is than strong enough for turbo manifold? do you brace it?
what is a better material/thickness for the turbo manifold? ie: schedule 10, 40 or guages
do you want to retain heat or disperse it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RMF »</TD></TR><TR><TD CLASS="quote">
Not me .I use 1 3/4 16 ga. and I hit the end of the tube with a rubber mallet then it fits the port perfect.</TD></TR></TABLE>
huh, never tried that size, i'll have to give it a shot...
Nick_p
Welding / Fabrication
11
Dec 1, 2011 01:11 PM
