Cruise control "malfunction"
So a friend installed an alarm in his RSX and wired the ignition up so that you wouldn't have to clutch in while turning the key.
Well, now the cruise control does not work.
Is there a way to setup a dummy sensor or something for the clutch sensor?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [d »</TD></TR><TR><TD CLASS="quote">UCKDOWN]So a friend installed an alarm in his RSX and wired the ignition up so that you wouldn't have to clutch in while turning the key.
Is there a way to setup a dummy sensor or something for the clutch sensor?</TD></TR></TABLE>So, I assume it's an alarm/remote start, nothing extra is needed to bypass clutch safety switch, the A/RS has a wire marked as neg. (-) out when starting/running, or status out when running, probably being used for the transponder key bypass module, [if the car has a transponder key] or you can use any wire that has a ground out from the time the remote start is activated till at least till running or as long as car is on the remote start, connect that wire to the relay side of clutch safety switch, the switch supplies a ground to the starter relay
95gsr
Audio / Security / Video
Feb 5, 2002 04:47 AM
