can anyone help me? code 15
Old Feb 25, 2002 | 06:57 AM
turbo_ef9's Avatar
Default can anyone help me? code 15
i just got done doing another swap.. everything went fine until i cranked it up.. it wouldn't start.. it gave me a code of 15.. for ignition output signal.. i changed ignitors.. didn't work.. took off the distributor and put it in my b16 and it worked fine... umm.. the motor stays on when the key is off... the helms manual told me to change the plug with the ground and ignition wires(2 wire plug to the distrib), i did that.. still nothing.. then they said to check the ecu(i did that already), and it works fine.. instead of that gay 7800 rpm rev limiter.. hehe.. but anyone got any ideas? i'm guessing a short somewhere in the wiring harness? please let me know.. thanks..
Old Feb 26, 2002 | 06:51 AM
turbo_ef9's Avatar
Default Re: can anyone help me? code 15 (b16_ef)
i guess that this tech area is no tech area.. i know someone in here had the same problem! help me out guys.. this crap is getting me annoyed.... oh.. up up up
Old Feb 26, 2002 | 11:28 AM
Perfectionist's Avatar
Disconnect the two pin connector from the distributor. Turn the ignition on and measure the voltage between the black/yellow wire and and body ground. Do you read approx. battery voltage? (It comes from the ignition switch, so if not...trace the wire back that direction)
BTW..."the motor stays on when the key is off" would suggest you've got something majorly mucked up there in your wiring. Since I can't see your car from here, your guess would be as good as mine at this point.
Old Feb 26, 2002 | 12:33 PM
turbo_ef9's Avatar
Default Re: can anyone help me? code 15 (Perfectionist)
it doesn't litterally stay on.. like you know the dash lights? wella they are on but they are dim... the car is still on cuz after i pull the key out the ecu still reads the code hehe.. well i'm just guessing sometihng with the wiring also... i was thinking bout a short also.. hmm.. thanks alot though.. late...
Old Feb 26, 2002 | 12:36 PM
turbo_ef9's Avatar
oh.. and like when i keep cranking it.. it like would stop cranking.. like the starter would get stuck or something.. then i would stop cranking and it wouldn't crank cuz it seemed like the starter like got stuck or something? any suggestions about that.?
UNDER PRESSURE
Nov 21, 2005 02:19 PM
jonathancrx
Mar 19, 2005 01:33 AM
CiViC SiR
Jun 26, 2003 07:07 AM
