can anyone help? code 15
Old Feb 25, 2002 | 06:56 AM
turbo_ef9's Avatar
Default can anyone help? code 15
i just got done doing another swap.. everything went fine until i cranked it up.. it wouldn't start.. it gave me a code of 15.. for ignition output signal.. i changed ignitors.. didn't work.. took off the distributor and put it in my b16 and it worked fine... umm.. the motor stays on when the key is off... the helms manual told me to change the plug with the ground and ignition wires(2 wire plug to the distrib), i did that.. still nothing.. then they said to check the ecu(i did that already), and it works fine.. instead of that gay 7800 rpm rev limiter.. hehe.. but anyone got any ideas? i'm guessing a short somewhere in the wiring harness? please let me know.. thanks..
CRX-CHACE
Feb 27, 2013 04:57 PM
DESTROYDCB7
Jul 10, 2011 07:13 AM
90crvtec
Aug 19, 2005 07:19 PM
turbo_ef9
Feb 26, 2002 12:36 PM
