F*%! my 2 day old axle blew...wtf?
Old Aug 26, 2005 | 07:53 PM
Reelizmpro's Avatar
Default F*%! my 2 day old axle blew...wtf?
Okay, installed some 90-93 reman axles matched to my SK7 intermediate shaft. Test drove it and everything was fine. The next day, I go to make a slight U-turn and while accelerating, the damn drivers side inner CV joint blows! completely detaching itself and leaves me stranded. I'm thinking shitty axles but I want to be sure, nothing I did caused this. SK7 intermediate shafts use integra axles right?
Old Aug 26, 2005 | 08:49 PM
Nisif's Avatar
Default Re: F*%! my 2 day old axle blew...wtf? (Reelizmpro)
Not sure about them matching with SK7 intermediate shaft...Is that off of a DA? Did you happen to buy the axles from Autozone? Even though they have lifetime warranties, I've had some bad experiences with them
Old Aug 27, 2005 | 10:50 AM
99sonicbluegsr's Avatar
man i had that same **** happento me. it is so frustrating. i still haven't figured out my mine took a dump. good luck
Old Aug 27, 2005 | 05:53 PM
91tealhatch's Avatar
Default Re: (99sonicbluegsr)
it happend to me too, but the piece that goes into the tranny, is stuck in there and i cant get it out.
Old Aug 27, 2005 | 08:32 PM
jeff420's Avatar
Default Re: F*%! my 2 day old axle blew...wtf? (Nisif)
yes, the sk7 intermediate shaft comes off of 90-93 integra's.
Old Aug 27, 2005 | 10:54 PM
2point2's Avatar
did you let out the clutch a little hard? some aftermarket axles will break fairly easy if you are hard on them while at full stearing lock.
Old Aug 28, 2005 | 02:39 AM
davens's Avatar
While not one day, I've chewed up a set of Autozone reman axles within 5k. Just a couple autoxs, no drag racing and mild mannered street duty. I'll pay for some better quality from now on but some people never have a problem though.
Old Sep 8, 2005 | 12:50 PM
Reelizmpro's Avatar
Default Re: (davens)
I thought I'd write a little update for those who are searching. We removed the bad axle and found that it was the exact same length as the one we took out. My uncle brought it back to the remanufacturer who replaced it free. Installed the new one and haven't had any problems since. I'm thinking it was just a defective reman. Nevertheless I'm somewhat afraid to make U turns now.
Old Sep 8, 2005 | 01:40 PM
Tyson's Avatar
Default Re: (Reelizmpro)
sk7 is a DA intermediate shaft?
what engine are you using? LS?
did you take off the hub ring and the rubber ring on the axle?
Old Sep 8, 2005 | 01:51 PM
Reelizmpro's Avatar
Default Re: (Tyson)
Yes, SK7 is a teg intermediate shaft. I have a 1st Gen XSi B16 PR3 swap, SK7 inter. shaft and ordered 91 integra axles. Actually, the axles we took out had the rubber rings installed so we just left the new ones on the axles. Hasn't been a problem.
Old Sep 8, 2005 | 01:54 PM
Tyson's Avatar
well, im glad its working for you.
i just hear that when you use 90-93 axles on CRX hubs with a ZC intermediate shaft, you have to follow these instructions for it to fit properly and prevent binding. maybe with the b16 tranny, things are different.
Old Sep 8, 2005 | 02:08 PM
loodood's Avatar
just fyi....after swapping in my dohc zc, i went thru 6 reman. teg axles in 4 months; thought i had bigger problems. then i went to a new (non-rebuilt) axle and haven't heard a peep from either in the last 8 months.
brians356
24
Oct 16, 2015 12:55 AM
crex23
Oct 1, 2005 12:42 PM
crex23
Sep 29, 2005 08:34 AM
RedK
Jun 30, 2005 05:34 AM
hybrid901
Jun 3, 2002 11:42 AM
