How to adjust A/C compressor belt tension?
Old Aug 26, 2005 | 06:37 PM
95TEG's Avatar
Default How to adjust A/C compressor belt tension?
Need some help on how to adjust the a/c belt tension. My belt is too loose making it squeel when the compressor kicks on. Any easy way to do this?
Old Aug 26, 2005 | 06:54 PM
the_23rd_letter's Avatar
Default Re: How to adjust A/C compressor belt tension? (95TEG)
i might be thinking of the power steering but you should be able to loosen the bolts on the unit and move it up/out a little bit to tighten the belt up. if not there should be a separate pulley (the belt tensioner) its a little bronze one that doesnt run anything, just tightens the belt up. use the same method.
Old Aug 26, 2005 | 07:06 PM
pubestripe's Avatar
Default Re: How to adjust A/C compressor belt tension? (the_23rd_letter)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by the_23rd_letter &raquo;</TD></TR><TR><TD CLASS="quote">i might be thinking of the power steering but you should be able to loosen the bolts on the unit and move it up/out a little bit to tighten the belt up. if not there should be a separate pulley (the belt tensioner) its a little bronze one that doesnt run anything, just tightens the belt up. use the same method.</TD></TR></TABLE>
that is how mine was on my da!!! but i took it out now...lol.
Old Aug 27, 2005 | 06:24 AM
95TEG's Avatar
Default Re: How to adjust A/C compressor belt tension? (pubestripe)
Up
Old Aug 27, 2005 | 08:02 AM
memicah's Avatar
yea, what engine do you have? then we can tell you exact. thanks.
Old Aug 27, 2005 | 08:58 AM
GDR888's Avatar
I adjusted mine about 1 week ago in my GSR. 1st thing i did was i removed the bolt of the PS. loosen the belt and moved the ps aside. After moving it aside have someone to hold it so it wouldnt hang. You will see the pulley and a 10mm bolt pointing up. Adjust that 10mm bolt clockwise to the required tension of the belt. Hook the belt to the PS and bolt it up.
Modified by GDR888 at 3:48 PM 8/27/2005
Old Aug 27, 2005 | 08:55 PM
95TEG's Avatar
Default Re: How to adjust A/C compressor belt tension? (memicah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by memicah &raquo;</TD></TR><TR><TD CLASS="quote">yea, what engine do you have? then we can tell you exact. thanks. </TD></TR></TABLE>
B18B1 LS Engine
qhiggy
Jun 11, 2015 04:00 PM
v1crattlehead
Sep 12, 2009 12:38 PM
chads
Jan 9, 2004 10:42 AM
NoLipRacen
Oct 31, 2003 07:57 AM
andrewasf77
Jul 8, 2003 12:14 PM
