traction bar no no
i just bought me an LCON traction bar and it fits and everything the only problem is that i dont have a mount for my tranny because im using my stock tranny and d series motor. The only thing is there no mount on the bar for the tranny.
any possible solutions???
probably buy an oem one maybe
**** you guys are right and i have a sohc zc too hmm no im trying to think hard probably weld that existing piece on my stock to my new one. hmmmmmmm damn i dunno keep my stock one on and put the aftermarket one too ahhaa **** i dunno does anybody out there know what i can do???
Replace your remaining mounts with polyurethane ones, that should stiffen up the motor quite a bit.
It cant be too bad as long as your mounts are in ok condition. Mount kits for b series only have 3 mounts, so you should be good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slywfbpsi »</TD></TR><TR><TD CLASS="quote">not true, d-series engine have more front to back movement, Hence why most aftermarket motor mount inserts only sell the front and rear mounts inserts now.</TD></TR></TABLE>
Only due to weaker mounts.
The front and rear mount are the stabilizers, put just 1 solid mount in the front or back and watch what happens.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kid-honda »</TD></TR><TR><TD CLASS="quote">
The front and rear mount are the stabilizers, put just 1 solid mount in the front or back and watch what happens.</TD></TR></TABLE>How about a finding a solid rear mount for the ef, so you can run a non front mount traction bar.
If you run a tight rear mount either aftermarket or just inserts you can get away with only 3 mounts. However, if you start making big power and/or running on slicks, you NEED a front mount. This is from personal experience, I cracked the rear crossmember in my CRX last year on three mounts.
Ash J. Williams
20
Jan 9, 2013 08:00 PM
p1driftfiend
Jun 3, 2004 06:37 AM
