Tried searching...no luck. Can you use Integra exhaust pipes (B pipe, etc....) on a 2000 Civic Si?
Old Aug 26, 2005 | 04:50 PM
bonylad's Avatar
Default Tried searching...no luck. Can you use Integra exhaust pipes (B pipe, etc....) on a 2000 Civic Si?
My plan is to use larger pipes and a header with the stock muffler for a little bit more flow with stock looks and nearly stock sound.
Anyone?
If not can you please point me in a direction to get larger pipes? Not KTellers. Good stuff he has, but too rich for me at this point.
Thanks!
Old Aug 26, 2005 | 07:21 PM
bonylad's Avatar
Default Re: Tried searching...no luck. Can you use Integra exhaust pipes (B pipe, etc....) on a 2000 Civic
Anyone?
Old Aug 26, 2005 | 07:54 PM
bonylad's Avatar
Looks like you can? The difference being the muffler on a teg is shorter?
Can I get some confirmation?
Old Aug 26, 2005 | 08:02 PM
e jay one's Avatar
im pretty sure the integra header is longer vertically cause a b18 is taller than a b16.
Old Aug 27, 2005 | 04:55 AM
bonylad's Avatar
No sir, thats not what I meant. Physically, can I install the exhaust pipes AFTER the cat on my EM1? Will they fit and bolt up correct?
TIA
Old Aug 28, 2005 | 06:19 PM
bonylad's Avatar
Still looking for an answer here.
TIA
Old Aug 28, 2005 | 09:30 PM
99blusi's Avatar
I am pretty sure it's on the wrong side of the car...but you can always cut the pipe, flip it and re-weld it. I think it's about the same length.
yeahsirb16
Dec 22, 2008 04:21 PM
oodie
Honda Motorcycles
Jul 23, 2008 06:55 AM
mpociask
May 18, 2004 03:52 PM
Solo2Vtec
Jan 10, 2002 10:38 AM
