Will these Crane Cams work well with my LS Turbo?
Old Aug 26, 2005 | 04:40 PM
slammedef06's Avatar
Default Will these Crane Cams work well with my LS Turbo?
i have these Crane Cams lying around that i'd like to throw in my LS Turbo setup that i am building...i just want to know if they will work well with the turbo as opposed to the stocks. i'd rather put these in but i just want to make sure that i won't lose any power or benefits from installing these with the ls turbo... heres the specs and link to cranecams.com with the details...
INTAKE LIFT AT TDC= 0.030" EXHAUST LIFT AT TDC= 0.044" BACK OFF LASH ADJUSTERS BEFORE INSTALLING CAM. FOLLOW SERVICE MANUAL FOR TORQUE SEQUENCE OF CAMSHAFT BEARING CAP BOLTS.
http://www.cranecams.com/?show...shaft
Old Aug 27, 2005 | 02:27 PM
Default Re: Will these Crane Cams work well with my LS Turbo? (slammedef06)
does anyone know if these cams will be okay on a turbo ls, will i lose power due to the overlap or will they be as good as stock or better?
Old Aug 28, 2005 | 04:14 AM
StorminMatt's Avatar
Crane makes a turbo grind, the 101-0014. This is probabl the cam you want. Try to sell your cams and buy this grind.
Old Sep 1, 2005 | 10:33 AM
Default Re: Will these Crane Cams work well with my LS Turbo? (StorminMatt)
will i lose power? i just want to know whether i'd be better of with these or the stocks, i'd rather put these in cause i didnt get the stock cams when i bought my b18a so i'd have to go buy stock cams. i will get aem cam gears too.
dan's integra
May 25, 2006 12:06 PM
slammedef06
Sep 1, 2005 10:36 AM
redDAinteg
Jul 5, 2005 06:14 PM
Silverhatch
Nov 26, 2003 02:06 PM
spoon23_JDizM AkA SpOoN20
Oct 25, 2003 11:41 AM
