Sunroof issues? What to do now...
Old Feb 25, 2002 | 05:53 AM
io_burn's Avatar
New User
Default Sunroof issues? What to do now...
Hey guys,
When I first got my car last summer my sunroof was kind of difficult to open. I had to keep tilting it up and down using the switch before it would open. I would push the switch to open it, and the back would lift up like it is going to open, and then it does nothing. So pushing the switch again, I put it back down, and then back up, and after doing this like 5 times it would open. Once it got to the point where it was opening it wasn't slow or anything like that, so I'm not sure if the problem is the motor or what... but it WILL open, it just takes some persistance.
It was a real nice day out yesterday, and I tried to open it, and for like 5 minutes I was using the switch to lift it up and down, but it would never slide back. Has anyone had this problem? Is it easy to fix? Hard to fix? Any suggestions would be very helpful.
Old Feb 25, 2002 | 07:51 AM
therealciviczc's Avatar
Default Re: Sunroof issues? What to do now... (io_burn)
I had the same thing. I replaced the swtich, and it worked for a while, but now its starting to slow down again. It never gets stuck though. I'm putting my money on the switch for yours. It was the exact same symptoms. I would have to keep hitting it, then it would go slow sometimes, and other times it would go fine.
Old Feb 25, 2002 | 08:02 AM
io_burn's Avatar
New User
Default Re: Sunroof issues? What to do now... (therealciviczc)
Where did you get the new switch from? Was it hard to replace?
Old Feb 25, 2002 | 08:04 AM
WuShu's Avatar
New User
open it using the manual lever, then just shoot some wd40 on the sliders, grease tends to build up and it slows it down. mines gets stuck occasionally, wd40 fixes it right up.
Old Feb 25, 2002 | 08:09 AM
io_burn's Avatar
New User
Default Re: Sunroof issues? What to do now... (HondaCRX)
Where is the manual level located?
Old Feb 25, 2002 | 08:12 AM
WuShu's Avatar
New User
right behind the sunroof, theres alittle circular plug behind the dome light i believe.
Old Feb 25, 2002 | 08:29 AM
io_burn's Avatar
New User
Ok, yeah, I just looked. Under it there is like a 10mm, 12mm maybe nut... Do you turn that and the sunroof opens or what? (it's really really cold out today, too cold for ******* with my car )
[Modified by io_burn, 11:31 AM 2/25/2002]
Old Feb 25, 2002 | 08:31 AM
WuShu's Avatar
New User
yes
Old Feb 25, 2002 | 10:32 AM
89HF's Avatar
New User
My CRX came with a tool,it looked like a big offset screwdriver,but had a 5mm allen wrench on each end to close and open the 'roof.
Old Feb 25, 2002 | 02:02 PM
AfEn808's Avatar
New User
Default Re: Sunroof issues? What to do now... (89HF)
yeah its probably your switch mines has that problem it works sometimes you have to click it a few times.
Old Feb 25, 2002 | 02:50 PM
SiR Kid's Avatar
New User
Default Re: Sunroof issues? What to do now... (AfEn808)
Grease/WD40 those rails!
Old Feb 25, 2002 | 02:59 PM
insomniac791's Avatar
Default Re: Sunroof issues? What to do now... (SiR Kid)
mine did the exact same thing. I dont have 50 bucks laying around to buy a new switch so I took out my old switch and took it apart (it is fairly easy) and cleaned all the contacts. Put it back to gether and it has worked ever since. When I got the switch working and the sunroof opening and closeing right I wiped all the old gunked up grease off my rails and put some lithium grease back on it. It has been about 6 months and no problems.
If you need help takeing the switch apart e-mail me at insomniac791@yahoo.com
later
Matt
Old Feb 25, 2002 | 03:58 PM
Default Re: Sunroof issues? What to do now... (insomniac791)
I took a switch out of a civic at the junk yard.
Old Feb 25, 2002 | 04:14 PM
Meeatch's Avatar
I agree with the switch issue... I took my car to the Honda dealer for the same thing, and they said that the switch gets corrosion on the connectors due to the current that flows through them. They popped mine out, scrubbed the corrosion off, and presto! Just pop that baby out and give it a good scrubbing.
Old Feb 25, 2002 | 05:07 PM
io_burn's Avatar
New User
Default Re: Sunroof issues? What to do now... (Meeatch)
Ahhh thanks for the help everyone Next time the weather isn't ***-cold out here I'll fix it right up. (Having no garage sucks :X )
Mr.Death
28
Jul 13, 2011 02:41 PM
rjmancia
Sep 12, 2008 09:54 AM
96gisar
Dec 21, 2007 02:02 PM
ferio 95
Mar 3, 2005 04:47 AM
SLOAZZ95
Oct 2, 2003 01:37 PM
