oil question
Old Aug 26, 2005 | 12:19 PM
Jordans95si's Avatar
Default oil question
i'm changin my oil, but i have one quick question, just to make sure, where is the nut/bolt that i have to loosen, its just right on the bottom of the engine right, and will i need to get a new one to replace it or a new washer or something?
Old Aug 26, 2005 | 12:41 PM
bby6's Avatar
I <3 Rotas
Default Re: oil question (Jordans95si)
Yes it's underneath your car, there will actually be writing saying "oil" or something like that. You should replace your washer not the bolt, if you buy your filter from honda they give you a washer or you can pick one up for like 20 cents.
Old Aug 26, 2005 | 12:44 PM
LudeyKrus's Avatar
It's the 17mm, IIRC, on the bottom lip of the engine oil pan; the bolt will be right above the bottom lip facing towards the rear of the engine bay.
Old Aug 26, 2005 | 04:00 PM
The Weather Man's Avatar
Make sure you take the old oil to your local station so they can recycle it. Don't dump it in the toilet or some crap like that.
Old Aug 26, 2005 | 04:03 PM
SKDRCR's Avatar
Default Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus &raquo;</TD></TR><TR><TD CLASS="quote">It's the 17mm, IIRC, on the bottom lip of the engine oil pan; the bolt will be right above the bottom lip facing towards the rear of the engine bay.</TD></TR></TABLE>
you are correct sir
paawk2000
Jul 16, 2007 07:54 PM
93(Civic)EG6
Nov 3, 2006 02:25 PM
RemerLex11
Mar 28, 2005 08:35 AM
Hairy Gorilla
Apr 17, 2003 10:51 AM
JDM88EF9
12
Sep 19, 2002 07:45 AM
