obd1 distributor with an obd0 ecu?
Old Aug 26, 2005 | 11:27 AM
p2motorsportcrx's Avatar
Default obd1 distributor with an obd0 ecu?
Is there any problem with running an obd1 95' distributor on an obd0 SI ecu?
I did a dpfi to mpfi swap (CRX, 1.5 dx block, 95' dx head, ex intake manifold) and I'm still not getting fuel out of the injectors, pump turns on, fuel in the rail, but no squirt. Main relay is fine and all connections are good, I get spark, and timing is correct. Does the type of injector matter as long as it fits the intake manifold? Any ideas?
Old Aug 26, 2005 | 11:37 AM
vtecn8ive's Avatar
Default Re: obd1 distributor with an obd0 ecu? (p2motorsportcrx)
nope
dizzy won't work
what type of injectors are you using?
Old Aug 26, 2005 | 01:35 PM
Default Re: obd1 distributor with an obd0 ecu? (vtecn8ive)
what exactly does dizzy mean? I'm using integra injectors form a 90' b-series. I just bought some used 90 civic 4wd injectors but haven't tried them yet. Is the injector firing order start on the right side(opposite the distributor) of the motor like the pistons do? 4321
Old Sep 24, 2005 | 06:48 PM
schwingding's Avatar
i was having the same problem with my 90 civic std after doing the conversion i was looking through some wiring diagrams and found the obd0 crank position and cyl position wires were switched around on the obd 1 distributor now the car starts and runs but is giving me a crank position cel and wont rev past 3-4 grand im not sure if the sensor is bad in the dizzy or what but that will get it running for you
Dandada
12
Apr 8, 2019 07:24 PM
delsol92
Nov 21, 2011 10:30 PM
brock316
Jan 11, 2011 09:07 PM
6doorsentra
Sep 16, 2006 11:11 AM
