quick help. engine almost dies at idle i searched
when i first start it up it idles at 2000 then i give it a lil gas and revs drop and then go up? everytime i give it quick gas it drops revs then goes up? then at idle when warmed up it starts dropping rpm to like 350 rpms. i norrow it down to a few things. but correct me if im wrong. main relay, or dizzy/ignitor/ eavc?. spark plugs are fresh and im gonna do cap and rotor today. anyhelp would be apreciated.
im not worried about the high revs!!!!!!. i know it has a fast idle when warming up.
what im saying is while im warming up if i hit the gas the revs drop instead of increase. like serious hesitation or something. then while im at a stop light holding the brake it saound like it want to die and engine rpm drops to like 350 then i have to gas it to keep it alive. btw its a 89 si
I have the same hesitation problem at startup too. It starts poorly, then when it is running, tapping the gas makes the revs drop then rise. I thought it started when I put new spark plug wires. I just thought it was because my motor hated the bosch wires. I don't have the dying problem though. How do I check for stuck IACV and vac leaks?
