b16 tranny removal help.
Old Aug 26, 2005 | 08:03 AM
88crxhfb16's Avatar
Default b16 tranny removal help.
I need to remove my transmission. Its a 1988 CRX HF with a B16. I don't know where to start. any have a walkthrough?? or link to one????
Old Aug 26, 2005 | 10:32 AM
88crxhfb16's Avatar
bump
Old Aug 26, 2005 | 11:08 AM
TH33G4MON3's Avatar
Default Re: (88crxhfb16)
take out your motor... because its going to be a bitch for some parts...
take out all the tranny bolts to the motor
make sure all the wiring is disconnected from the motor to the tranny
they should all just pop off at the connections very simple...
double check all the time to make sure all the bolts are out
and the protective plate is off on the bottom that protects the flywheel/clutch
use a sledge and a flat head screw driver and wedge the motor apart evenly on all sides
good luck it takes some energy I just finished doing this...
Old Aug 26, 2005 | 11:09 AM
Suck my DX's Avatar
Default Re: b16 tranny removal help. (88crxhfb16)
if u have never done this before...write down everystep on a piece of paper that way u dont get lost when u r putting everything back together
Old Aug 26, 2005 | 11:30 AM
gmptep1's Avatar
please do not take a sledge hammer and a screwdriver to your engine block and tranny, simply take your arms, wrap them around the tranny and jiggle it back and forth while pulling out at the same time. It will come off, and you won't harm your engine block or tranny, also, you don't have to pull the whole engine out, you can rest the engine on a jack take the axles out and remove the tranny with ease.
Old Aug 26, 2005 | 01:07 PM
g-ride-si's Avatar
^agreed, I dont know why everyone says take the tranny out? Ive had mine out quite a few times(was sent the wrong clutch twice) never had to take the motor out. And jiggling worked for me. Last time i did the clutch it took me about 3 hours total. That was also including time wasted waiting on flywheel to be resufaced.
Old Aug 26, 2005 | 03:08 PM
TH33G4MON3's Avatar
Default Re: b16 tranny removal help. (gmptep1)
omg its obvious that your not going to hurt anything as long as you gentle wedge the flat head in between and tap it in "just tap it in" "tappy tappy tap tap" your not going to do anything bad but help urself it'll wedge it apart enought to start pulling with ur friends not a bad thing good as long as you know what ur doing!
Old Aug 27, 2005 | 06:56 AM
88crxhfb16's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gmptep1 &raquo;</TD></TR><TR><TD CLASS="quote">please do not take a sledge hammer and a screwdriver to your engine block and tranny, simply take your arms, wrap them around the tranny and jiggle it back and forth while pulling out at the same time. It will come off, and you won't harm your engine block or tranny, also, you don't have to pull the whole engine out, you can rest the engine on a jack take the axles out and remove the tranny with ease.</TD></TR></TABLE>do you have to unbolt any of the Engine mounts???
Old Aug 27, 2005 | 01:31 PM
g-ride-si's Avatar
yes you have to unbolt 2 mounts. The pass. side mount and the front.
Old Aug 27, 2005 | 03:36 PM
88crxhfb16's Avatar
Default Re: (g-ride-si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by g-ride-si &raquo;</TD></TR><TR><TD CLASS="quote">yes you have to unbolt 2 mounts. The pass. side mount and the front.</TD></TR></TABLE> so, with the car sitting up on Jackstands. put a jack under the tranny unbolt the pass and front mounts and any connections to the tranny and it will be able to be lowered down enough to pull completely out right???
Old Aug 27, 2005 | 03:38 PM
g-ride-si's Avatar
Yes it should be. to make more room take the pass side mount completely off the tranny.
Old Aug 27, 2005 | 03:48 PM
wrXtian's Avatar
http://www.c-speedracing.com/h...h.php
this shows how to do the whole thing w/ pics.. the only difference is this tranny is hydro and you have a cable.. the cable is really easy to undo.. if u can't figure out how to undo the cable you shouldn't be pulling your tranny
Old Aug 29, 2005 | 03:42 AM
88crxhfb16's Avatar
Default Re: (D16A6_HF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16A6_HF &raquo;</TD></TR><TR><TD CLASS="quote">http://www.c-speedracing.com/h...h.php
this shows how to do the whole thing w/ pics.. the only difference is this tranny is hydro and you have a cable.. the cable is really easy to undo.. if u can't figure out how to undo the cable you shouldn't be pulling your tranny </TD></TR></TABLE>
i'm sure, I can figure out how to undo the cable, being as I turbo the car with no instructions. thanks for the link.
awesome link btw.
91_Civic_Hatch
Jun 17, 2007 11:11 AM
mreid04
Oct 6, 2005 02:42 PM
InjectedPerformance
May 15, 2005 04:21 PM
Mike17
Aug 8, 2004 10:34 AM
