97 LS LONG BLOCK LOW MILES, PHILLY AREA, PA
97 LS LONG BLOCK 70K MILES, SUPER CLEAN
, $550 PICKED UP, WILL MEET PART WAY. IF INTERESTED 610-329-0814. LEGIT ONLY
I tried to email pics of the hx wheels to you , but your email wouldnt go through for some reason
. I assure you the motor is super clean, legit & 70k on it, strait from a wrecked 97 ls.
-includes: intake manifold w/ iac valve, throttle body (no tps or map), obd2 injectors, fuelrail, valve cover, oilpan, crank pully, timing covers,etc...
-does not include: exhaust man., alternator, ps pump, ac comp., distributor, or mounts.
if you are seriously interested, I can take the motor 1/2 way to you, if you are in the market for an ls, you WILL NOT be dissapointed by this motor!!
if you are local.
. I assure you the motor is super clean, legit & 70k on it, strait from a wrecked 97 ls. -includes: intake manifold w/ iac valve, throttle body (no tps or map), obd2 injectors, fuelrail, valve cover, oilpan, crank pully, timing covers,etc...
if you are local.
KGB_JDM
Appearance Build Threads
54
Jun 20, 2010 06:28 PM
UNDERGROUNDAUTOSALON
Northeast (Sales)
Sep 3, 2005 05:17 AM
