need help asap with my gsr
whatsup, i have a problem witht the vtec on my gsr ( its swapped into my 91 integra with obd0 pr3 ecu) ...welll anyway only my exhaust valve is engaging ...i believe its due to a relay that was installed on the car that is run from the shift light the a plug under the intake manifold...i have called the previus owner and he told me the shift light when engaged sends power to a relay wich opens my secondary's...welll my secondarys are not engaging...is there anyway i can have the intake and exhaust lobes engage at the same time?
