Suspension & Brakes Theory, alignment, spring rates....
GC custom spring rate question
Old Aug 25, 2005 | 10:35 PM
LBDM EK97's Avatar
Default GC custom spring rate question
im going to purchase the gc/koni shocks and coilovers for my eg but don't know what spring rate for the GC to go with. any sugguestions? im planning on drag racing, road racing, and of course its my daily driver. what rates should I have in the front and in the back also im going to have itr front and rear sways. thanks
Old Aug 25, 2005 | 11:10 PM
slammed_93_hatch's Avatar
Default Re: GC custom spring rate question (LBDM EK97)
your not going to be road racing a DD car, you might do DE with it though.
I'd go with the OTS rates GC suggests, i don't think you would need anything more then that.
Old Aug 26, 2005 | 04:27 AM
ecahatch's Avatar
Senor Miembro
Default Re: GC custom spring rate question (slammed_93_hatch)
im set on koni/gc setup....btw, what is the OTS rate? (F/R)
Old Aug 26, 2005 | 05:52 AM
AutoXer's Avatar
Default Re: GC custom spring rate question (ECAhatch)
Off the shelf. It's what most people should get for a first setup.
Old Aug 26, 2005 | 10:18 AM
ecahatch's Avatar
Senor Miembro
Default Re: GC custom spring rate question (AutoXer)
ahhhhhhh i see...
Old Aug 26, 2005 | 11:00 AM
Marauder's Avatar
The spring rates are different for every application. GC tunes them for each chassis and even will change them if you've done a motor swap. Best bet, give them a call and tell them your setup and they'll fix you up!
Old Aug 26, 2005 | 10:46 PM
LBDM EK97's Avatar
Default Re: GC custom spring rate question (Marauder)
thanks for the responds..I just want to hit the tracks sometimes but also this car is my daily driver but thanks anyways
20CiviC02Si
18
May 30, 2012 10:18 PM
thewrai6th
Suspension & Brakes
Nov 4, 2009 05:01 PM
Destructive-
Suspension & Brakes
15
Sep 28, 2008 08:36 PM
JapSpec954
Jun 13, 2003 02:44 PM
gen2lsvtec
Aug 31, 2002 02:43 PM
