Crx Gas Tank Change
Old Aug 25, 2005 | 10:25 PM
coldtotouch's Avatar
Default .
Old Aug 25, 2005 | 10:28 PM
89s1's Avatar
Default Re: Crx Gas Tank Change (coldtotouch)
have as little gas in it as possible.
have a jack handy to lower/raise it instead of using your forehead
have fun.
Old Aug 25, 2005 | 10:30 PM
jisu009's Avatar
Default Re: Crx Gas Tank Change (89s1)
deep socket (11mm i think) and a drill to unscrew the nuts that hold the two straps up.
Old Aug 25, 2005 | 10:56 PM
Tyson's Avatar
Default Re: Crx Gas Tank Change (What does HBZ mean)
11mm!? what bolt on a honda uses a 11mm?? come on jisu, i know thats you under that lame id...
Old Aug 26, 2005 | 01:04 AM
gnar kill's Avatar
Default Re: Crx Gas Tank Change (Tyson)
yeah all the bolts are 10's....just did it. its not too bad just don't lose the washers on the banjo bolt going into the fuel pump
Old Aug 26, 2005 | 05:18 AM
fireant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">11mm!? what bolt on a honda uses a 11mm?? come on jisu, i know thats you under that lame id...</TD></TR></TABLE>
A stock exhaust manifold shroud bolt with .5mm of rust.
Old Aug 26, 2005 | 10:23 AM
DUFFM4N's Avatar
Default Re: (coldtotouch)
u can take honda's apart with 10,12,14,17mms
thats wut i love about em
Old Aug 26, 2005 | 01:05 PM
Targa250R's Avatar
be professional
Default Re: Crx Gas Tank Change (fireant)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fireant &raquo;</TD></TR><TR><TD CLASS="quote">
A stock exhaust manifold shroud bolt with .5mm of rust. </TD></TR></TABLE>
Ain't that the truth
Old Aug 26, 2005 | 03:49 PM
Mattamotor's Avatar
Default Re: Crx Gas Tank Change (Targa250R)
yeah but then the 11 will jist strip. normally with rust you go down a size and hit a junk socket on with a hammer. works everytime.
As for the gas tank all great tip amd be patient, you dont want to break any of the numerous hoses.
Old Aug 26, 2005 | 04:00 PM
jisu009's Avatar
fine...i got one wrong. I thought it was a 10m the whole time, but my roommate (Rice_Classic) just changed his tank and asked me for an 11m while he was under the car.....to undo those nutz.
Should have gone with what I know.....
Old Aug 26, 2005 | 11:46 PM
Tyson's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by What does HBZ mean &raquo;</TD></TR><TR><TD CLASS="quote">
bitches and ho's?
Old Aug 26, 2005 | 11:49 PM
jisu009's Avatar
bitches and ho's? </TD></TR></TABLE>
and ho's and bitches!
Old Aug 27, 2005 | 10:19 AM
njn63's Avatar
how much does the stock tank weigh? Just a rough guesstimate. I've been debating a fuel cell and how much weight savings i'd have from it.
Old Aug 29, 2005 | 09:46 PM
jisu009's Avatar
Default Re: (njn63)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by njn63 &raquo;</TD></TR><TR><TD CLASS="quote">how much does the stock tank weigh? Just a rough guesstimate. I've been debating a fuel cell and how much weight savings i'd have from it.</TD></TR></TABLE>
You won't be saving much if any weight from going to a fuel cell.
npor
Dec 7, 2006 09:19 PM
heretolearnandteach
Oct 22, 2006 12:58 PM
silverEH2
Feb 6, 2003 10:02 AM
gOSetonHall
Sep 6, 2002 12:56 PM
