f22 harness h22 motor
I used the F22B1 harness for my swap on my accord. just had to add knock sensor and IAB wires as well as lengthen a couple of wires. If the motor didn't have VTEC you will have to add the wires for that.
are you 100% sure about this because i'm having issues with the car.. itz reving from 1-3k rpm and someone told me that it is a wiring issue *cuz of the harness* thankz for responding.
check your tps sensor wire, i think you might have mixed it up with your map sensor wire, they are both the same 3 prong plug and they can plug into each other. i remember my car was doing the same thing and that was the problem.
I didn't say yours was the F22B1 I was just saying I used MY F22 harness and it worked I am sure yours will. If you don't like the others responses get a manual and compare each wiring diagram.
welpz.. a little update... i got my exhaust put on today and for some reason the idle didn't jump up and down anymore.. it just stayed at a constant 3100... but than after i started it up the rpm started surging up and down again from 1-3k again... than after i started driving it stayed at a constand 3k.. someone please help me solve this problem!!!
RSR_Mike
Jul 20, 2011 11:19 PM
OneMadAccord
Nov 4, 2009 08:19 AM
