D16a6 valve lash?
just picked up a 90 Si and i'm going to change the oil and freshen up the valve cover gasket/grommets and do a valve adjustment. i just read in the haynes the same specs (Intake: .007-.009
Exhaust: .009-.011).
Then I had a question so as any good h-t'er I searched first and found this thread.
I am used to doing adjustments on my 00 Si and the specs are
Intake: .006-.007
Exhaust: .007-.008
I realize the different motors have different specs, but whats up with the difference, in that the b16 has .001 of discrepancy and the d16 has a .002 range? just curious as to why the d16 has more room to play with, and what the difference in driving/performance would be by setting them at I-.007/E-.009 vs. I-.009/E-.011?
Intake: .006-.007
Exhaust: .007-.008
very interesting. at this point i'm thinking of going within spec because it is a stock motor with 178k. i just got it and i need it as a daily driver until i get the 00 Si rebuilt again. i think i'll try the tighter specs next time!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx »</TD></TR><TR><TD CLASS="quote">Intake: .007-.009
Exhaust: .009-.011
You know I've done too many valve adjustments when I know that off the top of my head
i agree with you on that one, but you know you do it alot when you buy the took so you can almost do it with one hand
Exhaust: .009-.011
</TD></TR></TABLE>i agree with you on that one, but you know you do it alot when you buy the took so you can almost do it with one hand
i'm going to try to keep this thread on topic, but going into more detail. i got the car up and the oil drained and a new filter on. i got the wheel off. how cute - the d16's crank bolt spun inside the 19mm socket i had brought out. broke out the 17mm and now i got the crank spinning. its dark and cold out here. i spun the crank damn near twice before i saw any notch at all in teh pulley. it looks like 2 tiny notches on the pulley on the guides surrounding the alternator belt. is that about right? or should i be seeing more visible notches? ok i'm gonna pull the cover now... (got this on wifi in the garage for easy access)
ok so i decided to actually read the haynes before going further and see that to find TDC you have to pull the dizzy cap and mark the #1 cyl...is that the only way? well, back to it...
why does the d16a6 valve cover have 2 threaded holes on the front of it and why are they not plugged up? the pics in the manual show the same thing.
well i only got so far- this car is too old and i need more rubber gaskets/seals/etc to continue. back to the honda parts counter...to be continued...
no ya dont, i dont replace anything when i adjust my valves. and i always check TDC by putting a LONG screwdriver down each of the spark plug holes and turning the motor by turbing the cam gear with a wrench. much easier than going under the car to turn the crank.
Brett
Brett
STD, can you elaborate? Do you watch the screwdriver rise/fall from the piston, and get it to its highest point? Because even doing it by the Helms I never feel like I have it perfect by just looking at the notch except for #1.
yes, i watch it rise and fall. when it gets to its highest point, its at TDC. BUT i use the cam gearfor reference 1st. line the cam gear up with the notch on the inner timing cover then drop the screwdriver into cyl one. it will be at TDC Cly 1. then, when done adjusting the valves on cyl one (always intake 1st!) then take the screwdriver out, drop it into cyl 3 and turn the cam gear 1/4 turn. thats TDC cyl 3. then do 4 then do 2. BUT MAKE SURE ITS AT TDC. cause remember, the piston is at tdc 2x. you know yer right when u feel a little whoosh of air come out. yer looking for TDC of the compression stroke. anything else u guys need?
Brett
Brett
wow, I wish I had had known this last month. The cars are both fine, but I wouldnt mind going in and doing it again with this method to get it better....but my poor back can only handle doing valve adjustments once in a while.
I'll definitely be doing this on the autocross car sometime in the spring...thanks for the tip!
wagon-r
Jun 11, 2013 09:32 AM
