Suspension & Brakes Theory, alignment, spring rates....
One coil sitting higher than the other?
Old Aug 25, 2005 | 08:29 PM
Crono139's Avatar
Default One coil sitting higher than the other?
I altered my suspension for the first time in a good while just a few days ago. I'm dropped on a set of Tein coilovers, and my uncle did the install just over a year ago.
When I jacked up the front, and took off the front wheels, it appears that the driver side coilover sits differently than the passenger side.
Right now, with the driver side, I have two notches left on the coilover, and I have at least three times as many notches left on the passenger side. But yet, the car is even on both sides. 1 1/2 finger gap in the front.
Does this sound normal to you guys, or should I bring this across my uncle?
Old Aug 26, 2005 | 03:31 PM
Crono139's Avatar
Default Re: One coil sitting higher than the other? (Crono139)
Anyone?
Old Aug 26, 2005 | 06:51 PM
Crono139's Avatar
Old Aug 26, 2005 | 07:08 PM
EtherGhost's Avatar
Have you thought about the fact that one side of your car probably weighs more than the other, and that the uneven coil height actually makes the ride height even?
Old Aug 26, 2005 | 07:11 PM
Crono139's Avatar
Default Re: One coil sitting higher than the other? (EtherGhost)
I have.
But it would be that big of a difference? That's what worried me.
Old Aug 26, 2005 | 08:07 PM
chrisw85's Avatar
its possible the front/rear springs were put on incorrectly side to side. That is if the springs are different lengths front and rear for Tein's which i dont know.
Old Aug 27, 2005 | 12:18 AM
Tyson's Avatar
its normal.
really, it is normal.
Old Aug 30, 2005 | 09:22 PM
CiSmoEk4's Avatar
this happened to me when i put my jic flt-a2s on. if you have a full coilover set-up your uncle might have put the coilovers on and noticed that the car didn't sit evenly and tightened the collar and compressed the spring to fix the height. If this is true, you should be able to make the spring longer by turning the collar (at least to where it is the same length as the other side) and then spin the actual threaded part for the collars around and lower that side that way. To make sure that both sides are even...either count the threads on the lower perch or use measuring tape. i hope this helps a little bit.
nicolas1320
Sep 10, 2010 08:56 AM
bchap
Suspension & Brakes
Aug 6, 2009 01:32 PM
Ryan97
Aug 15, 2007 11:38 AM
mikeunreal2
Suspension & Brakes
12
Jan 9, 2007 10:04 AM
jayfowens
Jul 8, 2005 06:48 PM
