crx dual high beam bulb how to
Old Aug 25, 2005 | 05:50 PM
solfly's Avatar
Default crx dual high beam bulb how to
thought it was in the FAQ anyone know where it is
Old Aug 25, 2005 | 08:01 PM
88 rex's Avatar
Default Re: crx dual high beam bulb how to (solfly)
Buy the bulbs then all you have to do is dremmel out some of the plastic clip on the light bulb. Piece of cake. I have them, and it was a breeze to do.
Or take out your high beam bulb and compare it to your low beam bulb and you'll see what part you need to dremmel in order for the bulb to slide into the clip.
One important thing though. You'll need the rubber O-ring from the low beam bulb on the new high beam bulb. Just slip it over and you'll be fine.
Someone correct me if I'm wrong (it's been a while since i've done it)
MakoE2
Sep 6, 2005 12:59 AM
hYpE-R-29
Dec 29, 2004 04:14 PM
paulyman
Apr 1, 2002 07:17 PM
intevic2010
Oct 16, 2001 09:34 PM
