Will a 95 ls wireharness work with a 91 ls integra?
Old Aug 25, 2005 | 05:47 PM
swtch7's Avatar
Default Will a 95 ls wireharness work with a 91 ls integra?
just trying to get a quick response. thanks.
Old Aug 25, 2005 | 05:50 PM
mericbe's Avatar
Default Re: Will a 95 ls wireharness work with a 91 ls integra? (swtch7)
Motor harness? Like 95 motor into 91 car or 91 motor into 95 car? The only difference I think noit for sure is that the 91 motor harness does not have the O2 sensor for the exhaust mani like on the 95.
Old Aug 25, 2005 | 05:52 PM
swtch7's Avatar
Default Re: Will a 95 ls wireharness work with a 91 ls integra? (mericbe)
yea the motor harness. actually a 95 motor harness for the 91 ls. and would that work with the 91 ls ecu?
Old Aug 25, 2005 | 06:00 PM
mericbe's Avatar
Well in theory it should work b/c there is no need for the O2 sensor then and and converting the motor to OBD1 (make sure your using OBD0 Injectors off the 91 LS motor). The only problems I see would be at the strut tower where it clips into the body harness and maybe at the dizzy, but I heard that the dizzy's are the same. If it wires clips into at the strut tower and it does not clip into the dizzy u can always rewire the 91 clip onto it and just match the wires. The only way to tell is just to try it out. A new harness is like around 100-150 buck and used like around 50. I would just try it its like 20 mins changing wire harness and you dont even have to jack up car.
Old Aug 25, 2005 | 06:04 PM
swtch7's Avatar
hey mericbe, thanks for all your input. Its not actually for me, im selling the harness and this guy was asking me about it. I just didnt want to be like yea sure it works then to find out later it didnt. But I agree with you, i think it will work maybe just a little extra wiring after its all said and done. anyhow thanks for your quick response!
Old Aug 25, 2005 | 06:06 PM
projectTeG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swtch7 &raquo;</TD></TR><TR><TD CLASS="quote">hey mericbe, thanks for all your input. Its not actually for me, im selling the harness and this guy was asking me about it. I just didnt want to be like yea sure it works then to find out later it didnt. But I agree with you, i think it will work maybe just a little extra wiring after its all said and done. anyhow thanks for your quick response! </TD></TR></TABLE>
your trying to put the engine harness from a 95ls on a 91 ls engine right?....are you going to use the 95 injectors and dist. and do a obd1 to a obd0 conversion?
Old Aug 25, 2005 | 06:11 PM
mericbe's Avatar
Default Re: Will a 95 ls wireharness work with a 91 ls integra? (projectTeG)
There is no conv. Your still using the stock OBD0 ecu, dizzy, and injectors. He is just using the harness.
Old Aug 25, 2005 | 06:17 PM
swtch7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mericbe &raquo;</TD></TR><TR><TD CLASS="quote">There is no conv. Your still using the stock OBD0 ecu, dizzy, and injectors. He is just using the harness.</TD></TR></TABLE>
correct
Old Aug 25, 2005 | 06:24 PM
LeftCorner's Avatar
Extra wiring will be necessary for the resistor box. The coolant temp. plug is in a different spot w/ a different plug and the O2 sensor uses a different plug.
Old Aug 25, 2005 | 06:29 PM
mericbe's Avatar
Default Re: Will a 95 ls wireharness work with a 91 ls integra? (LeftCorner)
I'd go w/ him.
Old Aug 25, 2005 | 06:30 PM
projectTeG's Avatar
arent the plugs different since one harness is obd0 and one is obd1?
BryanR
Sep 5, 2010 02:05 PM
boosted96midorihatch
Sep 16, 2006 10:25 PM
lol_on_v8s
Aug 23, 2006 10:13 AM
efkilla
Aug 15, 2006 06:06 PM
AzntaggeR
Oct 19, 2003 11:49 PM
