Quick Question on GSR Seats and EG Rails
Old Aug 25, 2005 | 04:54 PM
litterbox's Avatar
I am a (Trial User) Army
Default Quick Question on GSR Seats and EG Rails
Hey,
I know that only 3 bolts line up when you put GSR seats in an EG. Can you just swap to civic rails? Or do you need to swap the entire seat pan?
Old Aug 25, 2005 | 05:40 PM
mulletov's Avatar
i always thought 92-95 civics and integras had the same seat rails and brackets. oh well, if that is not the case, then check this out. It's for swapping integra seats into a 96-00 civic but you get the idea of what u need to do. >>> http://www.geocities.com/bezean/rseat.html
swap the inside bracket with the belt buckle and swap the rail only on the outer side of the seat.
Old Aug 25, 2005 | 05:59 PM
futurefastguy's Avatar
Default Re: (mulletov)
my gsr seats were direct bolt ons in my eg hatch, but the gsr bottom piece for the back wont fit. it gave me a half in gap all around the hooks won't meet either.
Old Aug 25, 2005 | 10:46 PM
BlueIntegraBoy's Avatar
Default Re: Quick Question on GSR Seats and EG Rails (litterbox)
George, Integra seats should bolt up fine. But to answer your question, you can swap the inner EG rail onto the Integra without swapping seatpans.
Old Aug 25, 2005 | 10:49 PM
SirRevvs's Avatar
Default Re: Quick Question on GSR Seats and EG Rails (BlueIntegraBoy)
Integra and EG have the same bolt locations for the seats. If you use the GSR rails your seat will sit a little higher, but IMO I like it better that way
95 GSR seats in EJ1 coupe.
Old Aug 26, 2005 | 02:50 AM
litterbox's Avatar
Default Re: Quick Question on GSR Seats and EG Rails (SirRevvs)
Ok, thanks guys.
EGdope
May 22, 2012 01:48 PM
ChillinInTheDA
Dec 31, 2010 03:57 PM
BMun-Eh3
Dec 9, 2009 10:50 PM
bakertime
May 12, 2008 04:45 PM
verseone
May 2, 2004 12:20 AM
