Help! Car won't start, and I dont want to drive my beater ford escort no more!
Old Aug 25, 2005 | 04:53 PM
mericbe's Avatar
Default Help! Car won't start, and I dont want to drive my beater ford escort no more!
Ok I'e tried everything. Well first off my Starter Cut Relay went out so I jumped it. Its getting spark for sure, I changed Dizzy's, and I am getting spark from both when testing for spark. The car hasn't been cranked in a couple months so I figure the fuel injectors were gummed up so I get some starter fluid spray in the th. body. Started car and ran perfect for a few seconds, sputtered and died and I repaeated a couple times thinking the injectors were clogged. The car is in time because it was running perfect and u could just tell as well from the hum of the Greddy Exhaust. Oh, it sounded so perfect! Sorry I haven't drove my Honda in like 6 months, been stuck with a 91 Ford escort, yes OUCH! Anyway, My check engine light is not coming on. So I ran a hot wire to the ECU and it's rapid firing but no check eng light. When I mean rapid firing the main relay and fuel injectors are clicking rapidly and can smell massive amounts of fuel in the Intake Mani. Ok, so I try again w/ the stater fluid sprqay agian, same thing. So I assumed its my map sensor so I took it off to check if clogged bu t appeared clean, started car again w/ sensor off, car started and tryied to die, plugged the map sensor hole on th. body and idle seemed to level out to normal, but then died. So I gave up for the night. Do u think it could be the map sensor? Oh yeah, one more thing my tach isn't working either. My tach wouldn't been able to read the rpms trying to start but it ran when the map sensor was off for like 10 sec and I was reving up to around 3g's by the way the exhaust was sounding. Any suggestions anyone?
Old Aug 25, 2005 | 05:09 PM
mericbe's Avatar
Default Re: Help! Car won't start, and I dont want to drive my beater ford escort no more! (mericbe)
bump
Old Aug 25, 2005 | 05:27 PM
mericbe's Avatar
Please Help somebody I miss my Honda!
Old Aug 25, 2005 | 05:28 PM
SuperSteve737's Avatar
What car/motor?
Old Aug 25, 2005 | 05:31 PM
mericbe's Avatar
Default Re: (SuperSteve737)
Sorry runnin 94 Civic Coupe DX w/ 94 B18B, GSR tranny, and stock ecu from stock LS Integ that the motor came from
Old Aug 25, 2005 | 06:16 PM
mericbe's Avatar
Default Re: (mericbe)
Any body?
HondaJDMLife
Aug 24, 2014 11:35 AM
civic46
11
Sep 12, 2010 05:25 PM
Chef Andre
Dec 29, 2007 07:54 AM
mericbe
Aug 26, 2005 04:23 PM
jesse d
Aug 6, 2004 06:19 PM
