Tranny and axel Q’s???
Old Aug 25, 2005 | 03:33 PM
FOMULA91's Avatar
Default Tranny and axel Q’s???
I was thinking to purchase some SOHC Si tranny for my D15B but does anybody know if the HF axel fit in the Si Tranny?
Old Aug 25, 2005 | 04:49 PM
Crx Jimmy's Avatar
Default Re: Tranny and axel Q’s??? (FOMULA91)
no
Old Aug 25, 2005 | 05:32 PM
sam385's Avatar
no.
different length and/or # of splines.
Old Aug 25, 2005 | 06:39 PM
FOMULA91's Avatar
Default Re: Tranny and axel Q’s??? (sam385)
So I need to purchase a different axel for both sides right.
Old Aug 26, 2005 | 06:49 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FOMULA91 &raquo;</TD></TR><TR><TD CLASS="quote">I was thinking to purchase some SOHC Si tranny for my D15B but does anybody know if the HF axel fit in the Si Tranny?</TD></TR></TABLE>
all 88-91 CRX/Civic axles are the same on thetransmission end, so yes your HF axles will fit the Si transmission - the CRX HF and Civic STD axles are smaller at the hub end, but transmission end is the same as DX, Si, EX, LX , etc.
Old Aug 27, 2005 | 01:24 AM
FOMULA91's Avatar
Default Re: Tranny and axel Q’s??? (jlicrx)
So one fits and the other dosen't correct?
Old Aug 27, 2005 | 02:32 AM
SLOASSREX's Avatar
yup... hf is a 23 spline hub, along with all std's and most dx models. if youre gonna swap the tranny just use your hf axles... if you plan on puttin any amount of power to the ground later then you will need to change over to a 5 spd dx or si model hub, which has 26 splines. hope this helps!
oh eah, try to make sure if your car is 89 or newer that you get an 89 or newer tranny.;
88 trannies have diff. spline count on the input shaft than the 89-up trannies
Old Aug 30, 2005 | 06:31 PM
FOMULA91's Avatar
Default Re: Tranny and axel Q’s??? (SLOASSREX)
Thanks for the info!!!
onemore
Jan 9, 2008 03:51 PM
spunautosports
10
Oct 28, 2006 10:08 AM
e jay one
May 26, 2006 01:34 PM
donaldmejr
Dec 13, 2005 05:48 PM
pdiddyparsons
Mar 19, 2003 09:34 PM
