crx si sunroof help
Old Aug 25, 2005 | 01:13 PM
neowave2109's Avatar
Default crx si sunroof help
my hard top sunroof closes but dosnt drop all the way down... like 1' 1/2 inch stay open from the end .... anyone have this problem ???
Old Aug 25, 2005 | 01:19 PM
SECURITY's Avatar
Default Re: crx si sunroof help (neowave2109)
Mine did this. The sunroof closes by a plastic piece screwed to the rail.. sometimes that piece gets broken or the screw comes loose. In my case it was the screw and I only found this out by stripping apart the whole interior to drop the sunroof!!! Had a good laugh at the time there.
You know you can also manually crank the sunroof closed with an alen wrench (The slot is somewhere around the dome light) if the above mentioned plastic part isnt busted.
Old Aug 25, 2005 | 01:45 PM
Tyson's Avatar
i agree. those plastic end caps on each side of the rails break easily. the sunroof panel is probably misaligned because of it. crank the sunroof back manually, then take the panel off the rails by using a 10mm wrench under the panel. then use a smaller, 8mm i think, to take off the plastic end cap on both sides. now you can totally remove the panel and realign and reassemble it.
its a totally pain. when mine broke, i had to train myself to NEVER fully open the sunroof, or itll get off track and i have to fix it again.
Old Aug 26, 2005 | 04:04 AM
Default Re: crx si sunroof help (oh_crx)
it seems like the same problem i had with my mazda protege lol car gave me problems than it was worth ...lol thanks for the info guys ill try 2 use da crank 2day cause the car is going out next week to get painted ....and i dont want white seats when i get back ...lol
Old Aug 26, 2005 | 05:38 AM
djsire's Avatar
the first and second reply are correct i had to do this like 3 weeks ago!!. thatdamn swrew was loose. well at least i diditn have to buy a new assembly. it would take you about an hour or 2 to fix if you got a manual.
Old Aug 26, 2005 | 06:59 AM
SECURITY's Avatar
Default Re: crx si sunroof help (djsire)
I have old pics of this stuff so I might as well post em.....
There's the screw that needs to connect the plastic yellowish piece to the thing that looks like part of a mousetrap in order for your sunroof to close.
That's what it would look like if the plastic piece is broken
A sunroof skin just for reference
Old Aug 26, 2005 | 07:03 AM
Newark Built's Avatar
* B A N N E D *
I wish i wouldve seen this post a year ago.
I had same problem with mine and after buying 2 sunroof assemblys off ebay and both had same problem i basically bit the bullet and bought a new tray and EVERY SINGLE moving part.
LoL i even tried to open up that lil assembly that houses that plastic part...didnt go to well...
O well now i have a completely new sunroof (i also have that carbon fiber sunroof panel that lets it stay functional ) and no worries
Old Aug 26, 2005 | 01:28 PM
can u out line the screw in red the one u are talking about ???
Old Aug 26, 2005 | 01:50 PM
menappi's Avatar
would this have anything to do with why my sunroof only closes all the way on one side, the other sides corner stays up, moves all the way forward and back but when it tries to go down the drivers side doesnt. how do i remove the sunroof. do i need to take out the headliner?
Old Aug 26, 2005 | 01:59 PM
Tyson's Avatar
Default Re: (menappi)
remove the panel first. follow the instructions i said above.
then you can see whats wrong.
that white plastic piece was always broken on mine as well. but it only prevented the broken (drivers) side from raising all the way. it kinda dragged against the roof as it closed.
if you want to drop the whole sunroof assembly, you have to take off the A pillar plastic on both sides, the dome line and interior plastic, then the headliner and it will be completely obvious how it all comes out.
Old Aug 26, 2005 | 02:34 PM
menappi's Avatar
Default Re: (Tyson)
i removed the top panel, and can find anything as to why it doesnt close on that one side, when a piece breaks off is it obviou from looking above. those pictures are a little confusing, because i can see alot of those parts lookin at the sunroof while its in the car, so im not sure whats what.
Old Aug 26, 2005 | 02:38 PM
Tyson's Avatar
then just drop the sunroof assembly. youll see whats wrong.
but, theres really nothing servicable. even that white plastic thing could not be repalced since its integrated to the rest of the assembly and riveted in. so dont get your hopes up.
Old Aug 26, 2005 | 03:12 PM
TH33G4MON3's Avatar
Default Re: (Tyson)
never had the problem sorry mine gets caught up sometimes... but just keep pressing the button and it'll unstick... and just tighten everything thats what I do... sorry if not much help
Old Aug 26, 2005 | 03:14 PM
Tyson's Avatar
Default Re: (TH33G4MON3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TH33G4MON3 &raquo;</TD></TR><TR><TD CLASS="quote">never had the problem sorry mine gets caught up sometimes... but just keep pressing the button and it'll unstick... </TD></TR></TABLE>
if thats your problem, then you need to take out the sunroof switch and clean out the contacts and it will work fine, all the time.
Old Aug 26, 2005 | 04:14 PM
« Re: (Tyson) « » 3:34 PM 8/26/2005 Reply Edit
thank you ....lol thats what i was talken about ...lol
Old Aug 26, 2005 | 06:52 PM
* B A N N E D *
Default Re: (neowave2109)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menappi &raquo;</TD></TR><TR><TD CLASS="quote">i removed the top panel, and can find anything as to why it doesnt close on that one side, when a piece breaks off is it obviou from looking above. those pictures are a little confusing, because i can see alot of those parts lookin at the sunroof while its in the car, so im not sure whats what. </TD></TR></TABLE>
Its not obvious from looking from below or above it when its in the car...you have to remove your interior peices the access all the screws that hold it in...ITS A PAIN IN THE ***- helps if you have another set of hands helping you.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menappi &raquo;</TD></TR><TR><TD CLASS="quote">would this have anything to do with why my sunroof only closes all the way on one side, the other sides corner stays up, moves all the way forward and back but when it tries to go down the drivers side doesnt. how do i remove the sunroof. do i need to take out the headliner?</TD></TR></TABLE>
Yep this dose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson &raquo;</TD></TR><TR><TD CLASS="quote">then just drop the sunroof assembly. youll see whats wrong.
but, theres really nothing servicable. even that white plastic thing could not be repalced since its integrated to the rest of the assembly and riveted in. so dont get your hopes up.</TD></TR></TABLE>
Actually the white plastic parts are servicable...
Its called the sunroof cable assembly.
Try to find a schematic, it will help alot...Local Honda dealership should be able to print one out for you...they did for me
Old Aug 30, 2005 | 10:37 AM
menappi's Avatar
Default Re: (Newark Built Kandy SiC-RX)
sorry to drag this on, but what exactly needs to be removed to remove the headliner. i removed the mirror, the rear quarter panels, the trim pieces that go alone the doors on the inside..?
Old Aug 30, 2005 | 02:36 PM
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menappi &raquo;</TD></TR><TR><TD CLASS="quote">sorry to drag this on, but what exactly needs to be removed to remove the headliner. i removed the mirror, the rear quarter panels, the trim pieces that go alone the doors on the inside..?</TD></TR></TABLE>
Think you need to remove the light also, your sun visors, i dont remember what else...its been too long. Try searchin, thats how i got my info on what to do when i did it like 2 years ago.
Old Aug 30, 2005 | 06:55 PM
SECURITY's Avatar
There is an amazing 21 page manual on just about everything you'll need to maintain the 2nd gen sunroof up there on google. Has good instructions on how to drop the panel and can answer just about every other question there is.
It's a pdf file...
http://download.honda-fanatics...f.pdf
Old Aug 30, 2005 | 11:11 PM
* B A N N E D *
Default Re: (_crx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _crx &raquo;</TD></TR><TR><TD CLASS="quote">It's a pdf file...
http://download.honda-fanatics...f.pdf</TD></TR></TABLE>
Good lookin out.
Old Oct 6, 2006 | 08:31 PM
Sequoyah's Avatar
Default Re: (SECURITY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SECURITY &raquo;</TD></TR><TR><TD CLASS="quote">There is an amazing 21 page manual on just about everything you'll need to maintain the 2nd gen sunroof up there on google. Has good instructions on how to drop the panel and can answer just about every other question there is.
It's a pdf file...
ryanmh22
11
Feb 8, 2012 05:22 PM
1slocrx89si
Apr 24, 2007 06:29 PM
CLE
Feb 20, 2006 08:01 PM
TenLarge
Jun 18, 2005 01:37 PM
gocivicgo
Jun 17, 2003 08:49 PM
