ls with b16a tranny?
Old Aug 25, 2005 | 11:49 AM
b16a27's Avatar
Default ls with b16a tranny?
how much will it take off my 1/4 mile if i run like a 15.3 now i heard like up to .5 sec is this true
Old Aug 26, 2005 | 12:04 AM
dannylDAsport's Avatar
Default Re: ls with b16a tranny? (b16a27)
u get more acceleration thats a fact, but time is depending on driver.
Old Aug 26, 2005 | 12:08 AM
DA9ReMiX's Avatar
more accerleration
Old Aug 26, 2005 | 02:01 AM
string's Avatar
Default Re: (DA9ReMiX)
You will only get "more acceleration" (and I use that term loosely) due to the fact that...
a) You will be in the lower rpm range for less time due to having shorter gears.
b) Upon entering the next gear, you will drop back to a higher rpm, therefore power level.
A shorter ratio gearbox/final drive does not put any more power to the ground. In the end, its all about the power.
You will get negligible difference over the quater mile.
0.5 Seconds, you're dreaming.
Old Aug 26, 2005 | 02:03 AM
ALMXDUPINTEGRA's Avatar
.5 is in range
Ls_dx
Nov 12, 2006 10:09 PM
crx1009
Apr 12, 2006 11:55 AM
n1div
Oct 14, 2004 09:38 AM
AzntstyleZ
May 19, 2003 08:54 AM
boosted hybrid
Mar 7, 2003 03:55 PM
