stock gsr IM-just dual runners open & no single
is there anything else to disconnect on the stock gsr Intake manifold,besides the vacuum canister and plug to make just the dual runners open at once instead of the single then dual bs.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jsnm »</TD></TR><TR><TD CLASS="quote">is there anything else to disconnect on the stock gsr Intake manifold,besides the vacuum canister and plug to make just the dual runners open at once instead of the single then dual bs.</TD></TR></TABLE>
It isn't "BS" - it was designed that way for a reason. I would suggest leaving the system alone, or if your setup warrants it, swapping to a different IM such as Skunk2.
