Quick question about clusters..
I tried to look it up on an online Honda Parts catalog, but I had no luck. I was looking for part numbers (different numbers would indicate different applications)
IE: 4cyl Ulev, 4cyl std, 4cyl EX (lamp for ABS), 6cyl std and 6cyl EX (Lamp for ABS).
You might try directing your inquiry to a local salvage yard. They use cross-compatability listings which tell them what will fit what.
The difference is in the calibration for the Tachometer, and where this occures. If it's done by the ECM, they "should" interchange. If it's done by the Tachometer, NO. It will call for a specific cluster for a specific application.
P
P
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P_Adams »</TD></TR><TR><TD CLASS="quote">I tried to look it up on an online Honda Parts catalog, but I had no luck. I was looking for part numbers (different numbers would indicate different applications)
P</TD></TR></TABLE>
Thanks dude..ill look into that!
P</TD></TR></TABLE>
utturkey
May 25, 2011 05:42 PM
