How long do stock axles typically last?
Old Aug 25, 2005 | 08:39 AM
Reelizmpro's Avatar
Default How long do stock axles typically last?
How long do stock Honda axles typically last? 100K ? What about axles in general assuming I don't race on them. I just changed the axles on my CRX B16A. The stock axles were so bad, that the inner joints fell apart when removing them. I assume they came with the swap.
Old Aug 25, 2005 | 11:29 AM
Reelizmpro's Avatar
Default Re: How long do stock axles typically last? (Reelizmpro)
c'mon this should be an easy one for fwd guys. Ballpark?
Old Aug 25, 2005 | 11:51 AM
CRX Toad's Avatar
It really just depends. I have had some go for 50K and some go for 10K. Most axles last quite a long time as long as you catch them before the boot completely blows out and the axle looses all the grease.
Old Aug 25, 2005 | 11:55 AM
red_EF9Si's Avatar
there are too many factors that determine axle life for you to ever get a straight anwser.
Old Aug 25, 2005 | 11:57 AM
NAS_OCSICNARF
Guest
Posts: n/a
Default Re: (red_EF9Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red_EF9Si &raquo;</TD></TR><TR><TD CLASS="quote">there are too many factors that determine axle life for you to ever get a straight anwser.</TD></TR></TABLE>
The same with clutches, all depends on the drive life it had.
Old Aug 25, 2005 | 12:03 PM
red_EF9Si's Avatar
Default Re: (NAS_OCSICNARF)
yep, for that matter the same could be said for just about any component in your car....brakes, tranny you name it.
Old Aug 25, 2005 | 12:21 PM
Outsane's Avatar
keep the boots from getting dry and they will last longer..
do less turns with the steering wheel turned all the way..
I would say 50k is pretty good..
Old Aug 25, 2005 | 01:49 PM
Reelizmpro's Avatar
Default Re: (Outsane)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Outsane &raquo;</TD></TR><TR><TD CLASS="quote">keep the boots from getting dry and they will last longer..
Thanks for the input. Yeah I know the joints life depends mostly on the boots. I was looking at some rubber treatment products I could spray on the boots every so often to keep them flexible and less likely to crack in the future. It sucks when the boot kits are like $30 when you can get the entire reman'd axle for $70!
Old Aug 25, 2005 | 02:03 PM
Outsane's Avatar
Default Re: (Reelizmpro)
just buy axles with a lifetime warranty..
and keep a spare set of cores..
makes life alot easier..
Old Aug 25, 2005 | 02:10 PM
civickiller's Avatar
my stock axles on my d went 206k when i bought it the boots were pretty much completely gone, not one drop of grease actually had spiders making webs in there. bought new boots greased it up no clicking, been racing on it for 20k. holds up just fine. but i just did a motor swap and i found out one of the cv boots had ripped so good thing i found it but im not gonna be using those axles anymore anyways
Old Aug 25, 2005 | 03:19 PM
red_EF9Si's Avatar
if your car is lowered, invest in a camber kit. your axles will last longer with little or no negative camber. also, most places will void the warranty if you tell them your car is lowered. i found out the hard way..
Old Aug 25, 2005 | 03:37 PM
INEEDMONEY900's Avatar
the height of the car will also change the life...
Old Aug 25, 2005 | 05:17 PM
sam385's Avatar
axles seem to last until the boots break and all the grease slings out.
i have seen axles last for 100K miles; the person kept an eye on the condition of the boots. i think he changed the boots 4 or 5 times.
H2BSTUPID
Feb 18, 2009 03:21 AM
ke98248
Jul 30, 2007 06:05 AM
prostreetonline
Jul 7, 2006 04:13 PM
killablaze
Nov 28, 2005 10:52 PM
boostlee
Dec 10, 2003 05:20 PM
