too lean
Old Aug 25, 2005 | 06:57 AM
silverboost's Avatar
Default too lean
What would be the reason for a stock d16 (with a short ram intake) be running too lean? threw a trouble code for low current to the O2 sensor, and then after that was cleared threw one for being too lean, need to pass emmisions, sum1 help!
Old Aug 25, 2005 | 07:00 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: too lean (silverboost)
96-up Civic isn't it?
I'll bet it's your valve adjustment, or lack thereof.
How many miles? Have you ever had the valves adjusted? I see "system too rich" or "system too lean" on OBD2 Civics with valves out of spec.
Either the valves are overdue for an adjustment, or perhaps someone just did them and did them wrong - I've seen both cases.
Unfortunately with OBD2 Civics this **** happens all the time. they throw bullshit check engine codes that are VERY vague in theor descriptions, and you're left trying tp fix it with little direction.
Get me the exact code number and I'll look it up on my All-Data here at my shop.
Old Aug 25, 2005 | 07:08 AM
120k miles, bought car used with that mileage, so not sure if it was ever done, dont have the code now, ill try and post it after work
Old Aug 25, 2005 | 07:25 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Default Re: (silverboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverboost &raquo;</TD></TR><TR><TD CLASS="quote">120k miles, bought car used with that mileage, so not sure if it was ever done, dont have the code now, ill try and post it after work</TD></TR></TABLE>
Cool let me know.
Since you're a Trial User your posts per day are limited, so instead of wasting one of your posts, simply edit the above post with the code number.
Old Aug 25, 2005 | 07:27 AM
JDM-97CX's Avatar
Default Re: too lean (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 &raquo;</TD></TR><TR><TD CLASS="quote">on my All-Data here at my shop.</TD></TR></TABLE>
Awww, half-data eh? I'll stick with our On demand 5.
El Diablo
Nov 10, 2011 06:09 PM
SexyHatchie
Aug 22, 2007 04:44 AM
sinister357
Sep 21, 2004 05:00 PM
