car shuts down
Old Aug 25, 2005 | 06:34 AM
Consistent1's Avatar
Default car shuts down
sometimes when I am slowing down (coasting) and push the clutch in while it is in gear or take it out of gear my car dies. no sputter, no surge just dies. could be doing 5-30 mph not in gear and the car just turns off. it starts right back up or if I am at a roll enough I just put it back in gear and it starts. any clue?
Old Aug 25, 2005 | 06:37 AM
IHateJDM's Avatar
Default Re: car shuts down (Consistent1)
my car started doing that about 2 wks before my dizzy died. apparently I had bearing failure and didn't know it.
Old Aug 25, 2005 | 06:40 AM
Duane_in_Japan's Avatar
Default Re: car shuts down (IHateJDM)
I am just typing here, take the cap off the dizzy and see if you see any rust color pouder in there, if so, get a sub assy and rebuild with your other needed good parts that are in your dizzy now.
Old Aug 25, 2005 | 07:04 AM
machine4321's Avatar
any mods done ...i light weight flywheel will sometimes cause this if there is other mods done along with it (tunnign can fix it )
but i would start around the dizzy as well
Old Aug 25, 2005 | 07:39 AM
Default Re: (machine4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by machine4321 &raquo;</TD></TR><TR><TD CLASS="quote">any mods done ...i light weight flywheel will sometimes cause this if there is other mods done along with it (tunnign can fix it )
but i would start around the dizzy as well </TD></TR></TABLE>
i do have a lighy weight flywheel but that was installed over two years ago. I will look into the dizzy issue. a jdm h22a, I can use a 92-95 civic dizzy correct?
Old Aug 25, 2005 | 07:41 AM
IHateJDM's Avatar
Default Re: (Consistent1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Consistent1 &raquo;</TD></TR><TR><TD CLASS="quote">
a jdm h22a, I can use a 92-95 civic dizzy correct?</TD></TR></TABLE>
make sure its the dizzy first, it could be something else. I bought a USDM lude dizzy for my jdm H, and converted it to internal coil when mine died.
Griff911
Honda Civic (2001 - 2005)
Sep 2, 2008 07:25 AM
sing
Jan 4, 2007 02:12 PM
nickolas388
Jun 3, 2006 06:52 AM
kikwear002
Jan 10, 2005 07:10 PM
IMMORTAL-B18
Jun 26, 2004 02:36 AM
