JDM Type-S + Boost
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [ S7H »</TD></TR><TR><TD CLASS="quote">]Would it be ok to boost this with stage1 skunk2 internals.. cams.. cam gears.. intake mani.. & tb?
Any problem with this at all?</TD></TR></TABLE>
the compression is would still be a little high for my liking, but as long as you get it tuned properly, it shouldnt be a problem
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq »</TD></TR><TR><TD CLASS="quote">Too much compression, I think, will not help you. But there is nothing impossible for the great tuner.</TD></TR></TABLE>
damn, he beat me to it
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [ S7H »</TD></TR><TR><TD CLASS="quote">]would i be better off just boostin from factory spec H22A type-s?</TD></TR></TABLE>
yes, those parts arent gunna help much
yeah thing is.. i wanted to go thru high tuned NA see how i go for figures... then if its possible.. boost on top of all that... didnt think there would be too much problems with that...
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by [ S7H »</TD></TR><TR><TD CLASS="quote">]yeah thing is.. i wanted to go thru high tuned NA see how i go for figures... then if its possible.. boost on top of all that... didnt think there would be too much problems with that...</TD></TR></TABLE>
doesnt sound like a good idea
the type s has 11:1 compression. higher compression is better for NA, and lower compression is better for turbo. The base H22 (10.1:1 compression USDM) is a better motor for turbo, and the type s is better for NA.
With skunk2 stage 2 stuff you are going to be blowing the air right out of the head. The cams are designed to keep the valves open longer to allow more air. Great for N/A shitty for turbo.
anyone know how skunk2 stage2 cams perform on idle.. are they rought at all?
much diff between stage1 and stage2 S2 cams besides from valvetrain upgrade? will i net more power and feel the difference?
go stage 2 with type S pistons. Go for the valvetrain upgrade as well. You should make power passt the stock 7400 RPM redline, and to rev her out you need the valvetrain. Do it all right the first time so dont have to pull apart the head again in the future. Be sure to look at your budget and stay within what you are allowing yourself to spend.
