Suspension & Brakes Theory, alignment, spring rates....
Dayum I almost got Fu@ked!
Old Aug 25, 2005 | 12:34 AM
Monkey Z.'s Avatar
Default Dayum I almost got Fu@ked!
One of my lugnuts fell off my car.. luckly I notice the wheel was making a shaking noise and pulled over in time.. the tip of the stud cracked..
Modified by Monkey-DA at 2:07 AM 8/26/2005
Old Aug 25, 2005 | 02:36 AM
Jan and Dean
Guest
Posts: n/a
Default Re: Dayum I almost got Fu@ked! (Monkey-DA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Monkey-DA &raquo;</TD></TR><TR><TD CLASS="quote">One of my lugnuts fell off my car.. luckly I notice the wheel was making a shaking noise and pulled over in time.. the tip of the stud cracked.. I was driving around with a slightly wobbling wheel all day anyway lesson learned MAKE SURE YOU TORQUE EVERY LUG NUT and put anti-seize on occasionally
Modified by Monkey-DA at 2:01 AM 8/25/2005</TD></TR></TABLE>
you sound like a dumbass
i lost the lugnuts for one of my wheels on my old crx.
so i put 3 on every wheel... drove it for 2 years like that. no wheel whobbling.
if it is whobbling you got more problems, unless you forgot to tighten all of the lugs on that wheel
Old Aug 25, 2005 | 05:14 AM
be.twenty's Avatar
Default Re: Dayum I almost got Fu@ked! (Jan and Dean)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jan and Dean &raquo;</TD></TR><TR><TD CLASS="quote">if it is whobbling you got more problems, unless you forgot to tighten all of the lugs on that wheel</TD></TR></TABLE>
this was probably the case and probably why 1 fell off to begin with.... either that or they were over torqued.
Old Aug 25, 2005 | 09:59 AM
D95si420's Avatar
One other thing is alot of us use PB blaster for stuck/rusted bolts and such,(Not shitty WD-40) I got some on the lugs from trying to pound out a cv axle that was stuck in the hub. Next day lugs were loose on my boys car just from the drive from and to work witch is only like 5 miles total. (That was the worst axle i have ever had to do, finally broke it loose with the 10lb sledge and big punch After i cleaned the PB blaster off the lugs with brake cleaner and re-torqued all was well. Needless to say i was checking them every day, cause i could never live with myself if someone got hurt due to the work i did or the parts i put on. Had u done any work on that side or had the wheel off for anything recently??
Old Aug 25, 2005 | 11:16 AM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jan and Dean &raquo;</TD></TR><TR><TD CLASS="quote">you sound like a dumbass
I'm not sure what sounds dumber to me: the title of this thread, or the fact that for 2 years you couldn't find a way to buy 4 lugnuts to put onto your car.
C'mon they're lugs. they cost a dollar or 2...
my wheel will wobble when i've only got 3 lugs on/torqued--but this is on a 5lug car...
Old Aug 25, 2005 | 04:11 PM
92vx6's Avatar
i drove with 3 for like 3 years cuz the one thing u put the lug nut on was stripped. no wheel hobble at all. all four of ur lug nuts must have been loose.
o0Jash0o
Sep 28, 2006 09:22 AM
noob
Jan 31, 2005 03:38 PM
TruNinja619
Dec 21, 2004 06:04 PM
KillerTofu
Apr 20, 2004 04:40 AM
