[FAQ] Post your fuel consumption, What's your hondas MPG?
Old Aug 24, 2005 | 07:44 PM
Jimmy's Avatar
Global Moderator
Default [FAQ] Post your fuel consumption, What's your hondas MPG?
Alright, seen alot of threads asking about how to save gas, how much your getting per gallon, etc.
Post-
Engine
Mods
Vehicle make
How many mpg your getting
'95 civic dx coupe
- jdm b18c (gsr) b16 tranny, skunk 2 im, SRI, apexi n1, chipped p28
I have yet to fill up and see how many miles i get on a full tank, but daily i'm only getting 22 mpg.. due to being untuned..
post up<FONT COLOR="red">!</FONT>
Old Aug 24, 2005 | 07:47 PM
suncoastcustoms's Avatar
Default Re: * Post your fuel consumption, What's your hondas MPG? (Jimmy)
1998 Civic HX D16Y5, bone stock, 27MPG at 98MPH (pretune up, just finished today).
Old Aug 24, 2005 | 07:50 PM
ABK's Avatar
ABK
this been covered so many times
96 EX coupe
Engine stock
Good suspension, clutch and shifter for obvious reasons (driving like a jackass)
36 mpg driving like an idiot at WOT whenever I feel like it. Can get 38 mpg if driving like a grandma
Modified by ABK at 5:07 AM 8/25/2005
Old Aug 24, 2005 | 07:51 PM
EK k kay's Avatar
99 hatchback, y7/y8 mini me w/ z6 tranny, apexi power intake, Ex header/cat/exhaust conversion (oem parts)
I get just around 30mpg, maybe more. I don't know what I get on the full tank because I don't want to strand myself somewhere
RudeBwaiSi's Avatar
00 Si w/ intake, header, exhaust ~30hmpg, ~24cmpg.
Old Aug 24, 2005 | 07:56 PM
tsdenny's Avatar
z6
i/h/e
ej1
27
Old Aug 24, 2005 | 08:03 PM
Jimmy's Avatar
Global Moderator
damn, glad to know that i'm not the only one getting shitty gas mileage.
Old Aug 24, 2005 | 08:21 PM
ekcivic9's Avatar
Default Re: * Post your fuel consumption, What's your hondas MPG? (ABK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ABK &raquo;</TD></TR><TR><TD CLASS="quote">this been covered so many times
96 EX coupe
Engine stock
Modified by ABK at 5:07 AM 8/25/2005</TD></TR></TABLE>
i have a 96 ex coupe, stock engine, but im only getting 26, and im driving like a granny how can i get up to 36 like you!!
Old Aug 24, 2005 | 08:25 PM
Jimmy's Avatar
Global Moderator
Default Re: * Post your fuel consumption, What's your hondas MPG? (ekcivic9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekcivic9 &raquo;</TD></TR><TR><TD CLASS="quote">
i have a 96 ex coupe, stock engine, but im only getting 26, and im driving like a granny how can i get up to 36 like you!!</TD></TR></TABLE>
Tune up.
- Spark plugs
- Plug wires
- Fuel filter
- Injector cleaner/seafoam
- dist cap, rotor button
- check to see if your catalytic converter is still intact on the inside..
all of the above listed can reflect on your gas mileage
ABK's Avatar
ABK
I really don't know. Well I don't have a cat but it won't help you that much. Try driving it like an ******* maybe that will help. I also spend like 40% of my driving time on the highway but going like 80 mph.
I also got no AC. I always coast in gear to the stop. Keeps the injectors closed with throttle closed.
Old Aug 24, 2005 | 08:47 PM
92ehatch's Avatar
b7 driven hard every day, curvy roads and city, 400 miles on a tank, so thats 30 smething
93 civic lx
mods Ram air intake
Old Aug 24, 2005 | 08:54 PM
kameleon23's Avatar
Default Re: * Post your fuel consumption, What's your hondas MPG? (93egsedan)
31 hwy 22 city
Turbo B16 Civic Si
360 hp
Old Aug 24, 2005 | 09:21 PM
Aphelion's Avatar
Default Re: * Post your fuel consumption, What's your hondas MPG? (kameleon23)
d16@5psi on e-manage
exhaust
flywheel
24 mpg on 70% highway driving over 70 mph at all times (my car sees redline everyday and if a modded car passes me, I play around with him/her )
low mpg even for driving like I do.. I'm guessing I'm running really rich since I haven't had it tuned, just got the stock e-manage fuel map.
Old Aug 24, 2005 | 10:19 PM
dmxsoulja3's Avatar
Default Re: * Post your fuel consumption, What's your hondas MPG? (Aphelion)
92 EH3
D16Z6
SRI
Stock headers
high flow cat - RS-R cat back
124k - 210-205-210-205 compression test, fresh tune up parts
average 38-40 mpg no matter how I drive it.
Old Aug 24, 2005 | 10:24 PM
Neighborhood Superstar's Avatar
-93 hatch
-26 mpg
-h22a4
-17x7
-intake, N1 pipe with R muffler.
Old Aug 24, 2005 | 10:26 PM
SirRevvs's Avatar
Default Re: * Post your fuel consumption, What's your hondas MPG? (dmxsoulja3)
94 EJ1:
B18C1 bottom end (stock)
B17A1 head (stock + GSR cams)
DC 4-2-1
Clutchmaster's 8lb flywheel
AEM short ram
Catback exhaust (hollow cat)
P72 (chipped with mugen program)
Si's on 205/50/15's
I used to get 20 mpg with the B18C1 head no matter how easy I drove it. Then I bent some valves and put the B17A1 head on and now I get:
25 MPG hard driving
30 MPG easy driving
:shrugs: I don't understand. Maybe the C1 head had slightly bent valves from the begining?
Old Aug 24, 2005 | 10:30 PM
2000psi's Avatar
From: We Cant Stop Here This Is Bat Country, So CaL, USDM
Default Re: * Post your fuel consumption, What's your hondas MPG? (=Gameover=)
99 4dr Y7 108K miles
-5 speed
- Y8 IM
-CAI
-Header DEI wrapped
-Catless
-Stock exhaust
-NGK blue wires
-recently seafoamed
I can pull 415-430 miles outta my 11.9 Gallon tank
doing about 5 WOT pulls on the streets per day and cruising at 2600RPM on the freeway at about 65MPH with a 2 minute warmup every morning
I make up for wasted gas on the streets by keeping it under 3K on the freeway.
Old Aug 24, 2005 | 10:33 PM
SirRevvs's Avatar
Default Re: * Post your fuel consumption, What's your hondas MPG? (2000psi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000psi &raquo;</TD></TR><TR><TD CLASS="quote">I can pull 415-430 miles outta my 11.9 Gallon tank
I make up for wasted gas on the streets by keeping it under 3K on the freeway.</TD></TR></TABLE>
That's the way to do it . I am envious of your gas mileage
Old Aug 24, 2005 | 10:42 PM
pdiggitydogg's Avatar
97 ej8 coupe (d16y8)
ihe, regular maint. 93,000miles
30-35mpg city
Old Aug 24, 2005 | 10:52 PM
f1z1c's Avatar
Engine d15b7, 350,000+ miles
Mods i/h/e
Vehicle make 93 DX sedan
How many mpg your getting 35 city, 42 commuting, 50 interstate.
Old Aug 24, 2005 | 11:05 PM
siregcivic's Avatar
92 cx hatch d16z6/dx tranny act stage 2 clutch, intake no cat exhaust stock muffler..
24 miles city/highway
Old Aug 24, 2005 | 11:10 PM
EG6-SIRII's Avatar
92 hatch
b16a2
ys1 trans
I/H/E
600 kilometres to the tank on 91 octane and beating on it all day long
Old Aug 25, 2005 | 06:15 AM
Jimmy's Avatar
Global Moderator
to tha tizzle!
Old Aug 25, 2005 | 06:19 AM
litterbox's Avatar
I am a (Trial User) Army
B7 raped every day 400miles per tank
Old Aug 25, 2005 | 06:49 AM
I Eat Glue's Avatar
2000 Si
b16A2
115K miles
I/H/E
exedy clutch and 8LB flywheel
misfiring cylinders (cant figure out why)
but i manage 28 MPG driving like a idiot or city driving and up to 35 mpg driving miss daisy
