Edelbrock Victor X for Integra - Need installation information
Guest
Posts: n/a
Hi guys. I've searched everywhere but I cannot find any place to show me the correct way of installing the Edelbrock Victor X intake manifold on my 95 GSR.
It's 31-4760 (part #) and the instructions that came with it are not the same manifold in the picture. I think this is the newer model? I've seen other ones also and they have less holes in the back and I have about 3 or 4 more holes in mine.
Here r some pics to show you what I'm talking about. Please, if anyone know where i can get instructions on what to put where, it'd really help alot. Thank you
This is the back part
This is the front
Please, if anyone knows where to plug what in, please help me. Thank you
This is the front
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Ej »</TD></TR><TR><TD CLASS="quote">Yea all those extra holes are for vaccum. Just plug the ones you dont need.</TD></TR></TABLE>
Sounds so easy...yet my brain says "no" I am not sure if I can just plug any of the vacuums to any of the holes??? But now after I took them out, I don't even remember where they go to or what they're connected to
Guest
Posts: n/a
<U>***BY THE WAY GUYS, THIS IS GOING INTO A 95 INTEGRA GSR***</U>
Ok, I have a few questions with some pictures.
Here goes....
What is the black thing cicles in green? How do I connect that to the new IM? Whats the hose circled in red? Where do I connect that to?
Ok and what's line A and line B used for? Where do I connect these to in the new IM?
What is the green thing circled? Where do I connect that to in the new IM?
Here's the last picture. What are those two lines for and where do I connect them to? Thanx
If anyone can help me that'd be wonderful. I know Trooper would. So Trooper, this pics are for you. Please help out buddy!!!! Thanx man
Modified by JDMoMo at 11:12 AM 8/26/2005
Here goes....
first pic red circle= goes to oil seperator and to intake mani any port
first pic greed circle= do not need
second pic line a = brake booster
second pic line b = do not need
third pic = do not need
last pic = purge control solinoid connect to mani any port like stock other fitting on solinoid goes to charcoal canister
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMoMo »</TD></TR><TR><TD CLASS="quote"><U>***BY THE WAY GUYS, THIS IS GOING INTO A 95 INTEGRA GSR***</U>
Here goes....
Modified by JDMoMo at 11:12 AM 8/26/2005</TD></TR></TABLE>
Here goes....
charcoal canister, for emmision purposes has charcoal in it and filters vapor from your gas tank. It is located kinda under your battery and fuel filter on gsr's and other hondas, black cylinder with if I rember correctly 3 vaccume lines hooked to it.
Guest
Posts: n/a
Ok, whats that thing connected to the fuel rail on the right side???
Is it the same thing I have circled on my picture 3? BTW...what is that black thing on my first picture? The big thing that's circled....just wanted to know the name and what it's used for. Thanx guy
in pic 3 it is your vaccume actuator for the dual runners (runners change at 4400 rpm on gsr) an the black box is the control valve and vaccume canister for it. your new intake has single runners so that is not need.
Guest
Posts: n/a
Hey guys. Im in a delama right now with this. I finally put my engine back in and installed the intake manifold but the hose are too short. What can I do? Is it supposed to be like that? Please let me know ASAP.
THANK YOU !!!
THANK YOU !!!
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by v4lu3s »</TD></TR><TR><TD CLASS="quote">get new hoses that are longer.</TD></TR></TABLE>
where should i go get those?? autozone or something like that?
wow...can't believe everyone on this thread didn't say a single thing people in GDD or of it's kind would've already said a million times...all of you guys get a thumbs up from me.
very helpful indeed.
now for you question of hoses...yes autozone does sell them. they are reletively cheap.
remember, you are installing a aftermarket part. not all the parts will not fit in perfectly or even fit at all. good luck.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trustbuddy »</TD></TR><TR><TD CLASS="quote">wow...can't believe everyone on this thread didn't say a single thing people in GDD or of it's kind would've already said a million times...all of you guys get a thumbs up from me.
remember, you are installing a aftermarket part. not all the parts will not fit in perfectly or even fit at all. good luck. </TD></TR></TABLE>
You are the man! Thanks bro I am going to head on over there today to get the hose I need. Thanx man
