Rims Help
Ok..i just got the car used..91 Accord DX..wheels has 4 lugs..what is the patern? 4x100?...Anyway im buying rims from 99 Acura CL with 4 lugs..Will this fit my car ?
Thanks
Thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RalliartRsX »</TD></TR><TR><TD CLASS="quote">You know whats funny?? I was just lusting after those wheels on craigslist as I wanted them for me car!!!!! Small world eh`</TD></TR></TABLE>
those are the sickest factory wheels to throw on a 4 lug accord IMO
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Clay@tirerack »</TD></TR><TR><TD CLASS="quote">You can use 205/50/16 or 215/50/16 on stock suspension. Either one will work fine. </TD></TR></TABLE>
Yes, either one will work fine. 205/50-16 is 0.5 percent smaller than stock in outer diameter, and 215/50-16 is 1.1 percent larger than stock. However, there are many, many tires to choose from in 205/50-16, whereas only a few come in 215/50-16. So I would advise concentrating on 205/50-16...
205/55-16 is 20 mm wider than your stock tire size (185/70-14) and it's also 2.8 percent larger in outer diameter. In addition to your speedometer and odometer being off, and the slower acceleration that will result, there's a good chance it will rub. But you'll have to try it to be sure.
Why did you get tires that are too big, when you knew which sizes would fit okay?
Thanks for the quick respone guy..i just got new 16' rims...i guy throw in some used tires with 205-55-16..he said it would fit..i got no cash at this time..tire will last me few month..so you should i even try putting on..paying for mount ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I386 »</TD></TR><TR><TD CLASS="quote">you should i even try putting on..paying for mount ?</TD></TR></TABLE>
Sure, go for it! Even if they rub, they might only do so on turns, when the suspension is compressed. They can probably get you by for a few months, like you say...
P.S. Free tires are my favorite kind of tires. Great "bang for the buck".
What's that for???
</TD></TR></TABLE>What's that for???
ProjektR
Mar 14, 2006 07:54 AM
markm859
Jul 5, 2005 08:19 AM
