h22a1 head/block, hondata s200, digital gauges
I have a few things for sale if anyone is interested. Prices don't include shipping.
I have an h22a1 head that came off of my 94 vtec lude. It's missing a few bolts in the cam covers, no dizzy, no water pipe, no valve cover, and no front coolant outlet and sensor. You'll see in the pics. It's dirty, so it'll need a cleaning before you run it, but it's fine. It ran perfect before i pulled it. It'd be perfect for a port and polish. In the third picture, it's the part that goes in the bottom left.
http://photobucket.com/albums/...Head/ 200 bucks <FONT COLOR="red">SOLD</FONT>
I also have the bare h22a1 block that came out of my lude. No crank, no girdle, no water pipe, basically what you see in the pictures is what you get. It has a small scratch in one of the cylinders, but slightly noticable with the fingernail. I'm thinking a hone job would be fine, but this block would be perfect to send out for sleeving.
http://photobucket.com/albums/...lock/ 100 bucks <FONT COLOR="red">SOLD</FONT>
My hondata s200 setup. I no longer need it as I plan on getting Neptune'd. It's the basic model. NO boost, NO 3 step. You'll have to purchase the boost option from Hondata if you want this for boost. For N/A and Nitrous applications, this setup is PERFECT! It will control your nitrous for you.
It has:
-Base system
-Data logging and Rom Editor Software
-ROMulator (for real time updates, no chip burner needed)
-PCMCIA Card adapter with two serial ports (so you can hook up the ROMulator and the blue box at the same time)
-I don't have the push button, but it is not needed with the s200 setup.
-I also don't have any capacitors or whatnot needed to chip your ECU. But there are plenty of people out there that will chip it.
http://photobucket.com/albums/...data/ 300
Dynotune Digital EGT and Fuel Pressure gauges. Specs of these gauges can be found at http://www.dynotunenitrous.com...t.asp They are red square gauges. Currently, the fuel pressure sender is still in the car, but upon interest, i will remove it since the car is just sitting in my driveway.
http://photobucket.com/albums/...uges/ 225 for both or 125 each
If you don't see a price you like, make an offer. Any questions, let me know!
Modified by ludeDVR at 11:04 AM 8/31/2005
Modified by ludeDVR at 10:13 AM 9/16/2005
Modified by ludeDVR at 2:01 PM 9/24/2005
It has:
-Base system
Let me get the sensor off the car and see what kind of condition it is in...i'd do 100+ shipping since i'd like to get 100 for it even...
Bump it up for the hondata!!
zad5
Northern California (Sales)
Jan 10, 2007 05:55 PM
