Is it true you can install any B series header on any other B series?
Correct. As long as the heads are the same, they will fit.
You may or may not run into problems with the header length (connecting to cat) or the ground clearance.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bonylad »</TD></TR><TR><TD CLASS="quote">So one from a GSR will fit my Si?
True?</TD></TR></TABLE>
Will it physically bolt on to the head? Yes, all B-series engines are the same in this respect.
However, as shamoo noted, you will likely run into issues with overall length, and the angle of the collector flange when you try to bolt it to the rest of the exhaust.
b20SedanEF
May 3, 2015 08:29 PM
mkinpwrat12g's
Jul 13, 2005 07:16 PM
93CivicSI
10
Mar 12, 2004 09:36 AM
