radiator leak dont know why/where?
Old Aug 24, 2005 | 02:52 PM
integGSR805's Avatar
Default radiator leak dont know why/where?
My friend has a 94 integra ls/vtec recently started to notice that the car was leaking radiator fluide from underneath the passenger floor panel can figure out where it came it or where it could be coming from and now the leak got into his car sounds strange any help plz
Old Aug 24, 2005 | 03:07 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: radiator leak dont know why/where? (integGSR805)
It's most probably the heater core. Does his heat work okay?
Old Aug 24, 2005 | 03:30 PM
Default Re: radiator leak dont know why/where? (shamoo)
yea his heater works where could i locate the heater core at?
Old Aug 24, 2005 | 03:31 PM
5 Speed AP2's Avatar
You check those hoses yet?
Old Aug 24, 2005 | 05:37 PM
Default Re: radiator leak dont know why/where? (5 Speed Dc2)
think it is the heater core is that the only porssible reason for radiator fluide to be leaking into the car? i would probably need to take out the whole dash to even get to the components huh?
Old Aug 24, 2005 | 05:53 PM
shamoo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integGSR805 &raquo;</TD></TR><TR><TD CLASS="quote">think it is the heater core is that the only porssible reason for radiator fluide to be leaking into the car? i would probably need to take out the whole dash to even get to the components huh?</TD></TR></TABLE>
I think that's the only way. However, the core could be just clogged, thus having backup coolant leaking through the inlet/outlet tubes from the engine bay. Try locating the inlet/outlet passages on the firewall, disconnect them, and put a garden hose on one end. See if water goes through okay, and check for leaks on the inside again.
Old Aug 24, 2005 | 08:16 PM
thanks for the advice ill give it a try... if that happend not to be the problem and the core needs to be replaced how much do you think it would cost to pay someone to do the labor plus parts?
dwn2earth922
Sep 12, 2009 10:00 AM
EGdrop6
Jul 20, 2006 07:19 AM
slikz714
Jul 12, 2006 03:40 AM
tkHBseries
Feb 19, 2005 06:48 PM
youngwon22
Oct 6, 2003 09:03 PM
