front sway bars?
Ok. I need a little help figuring a couple front sway bars I have that I need help with. The first on came out of a 94 4 door, the endlinks are straight up and down with bushings in between. like ef's. So I found another one from a 2 door that had a different style endlinkds? They looked similar to the front endlinks on my 00si,
L-shaped. can anyone give me info on which is better? the L-shaped seem sturdier?
newer style endlinks are from 24mm sway bar and seem like a better desigin. the other older looking styler is 22mm and what I believe to be worse endlinks. I am not sure if 24mm up fornt is 2 much with a 23mm itr rear bar. my 00si has 26mm fromt and 14mm rear. this is going on a 92 4 door
88browncow
Jan 28, 2011 06:15 PM
