blinkers wont work??? checked everything HELP!!!
Old Aug 24, 2005 | 02:22 PM
jdmjeff's Avatar
Default blinkers wont work??? checked everything HELP!!!
last month i was driving home when i heard my blinker bulbs dragging the ground... i replaced the bulbs and the blinkers wont even turn on? i checked every fuse under the hood and event the one to the left of the steering column? i couldn't find any blown fuses? nothings labled though? any help here! thanks
Old Aug 24, 2005 | 02:54 PM
jdmjeff's Avatar
Default Re: blinkers wont work??? checked everything HELP!!! (jdmjeff)
anyone, anyone at all....
jdmjeff's Avatar
Old Aug 24, 2005 | 03:54 PM
jdmjeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjeff &raquo;</TD></TR><TR><TD CLASS="quote">anyone, anyone at all....</TD></TR></TABLE>
Old Aug 24, 2005 | 07:57 PM
jdmjeff's Avatar
no one... come on people
Old Aug 24, 2005 | 09:44 PM
White cracker yeehaa's Avatar
if nothing is labeled then u don't know which fuse to look for...obviously there is no power going to the blinkers, maybe the two wires are touching each other? I'll go check my integ and let you know which fuse it is, or look online for the diagram of the fuse box...
Old Aug 25, 2005 | 09:23 AM
jdmjeff's Avatar
Default Re: (DC2KinG)
ok kool thanks also i looked at the wires and they didnt see to be touching? HELP!
Old Aug 26, 2005 | 06:48 AM
jdmjeff's Avatar
Default Re: (jdmjeff)
again!!!!
Old Aug 26, 2005 | 07:02 AM
Liquid Ice NF's Avatar
make sure ur hazard light button isnt pushed in.
Old Aug 26, 2005 | 07:30 AM
jdmjeff's Avatar
Default Re: (Liquid Ice NF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Liquid Ice NF &raquo;</TD></TR><TR><TD CLASS="quote">make sure ur hazard light button isnt pushed in.</TD></TR></TABLE>
its not also the hazord lights work fine... i need to know where the fuse/fuses are located in the fuse box? or if thats not it im not sure....
Old Aug 26, 2005 | 11:19 AM
jdmjeff's Avatar
b
u
m
p
jdmjeff's Avatar
d
m
u
p
Old Aug 27, 2005 | 08:59 AM
jdmjeff's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmjeff &raquo;</TD></TR><TR><TD CLASS="quote">d
m
u
p
Old Aug 27, 2005 | 07:36 PM
jdmjeff's Avatar
Old Aug 27, 2005 | 08:05 PM
projectTeG's Avatar
check your grounds....the should be near the head lights....they are like box looking things with like 8 wire in them. when i was doing my car swap i forgot to bolt one up and the whole left sides lights and horn wouldnt work.
Old Aug 27, 2005 | 08:25 PM
Naruto's Avatar
Default Re:
this may be a very small chance...but perhaps you're missing a fuse
Old Aug 28, 2005 | 08:21 AM
Germpeel's Avatar
i thought there was no bumping allowed.. other then that, use a volt-ohm meter and check ur wires
Old Aug 28, 2005 | 08:36 AM
jdmjeff's Avatar
Default Re: (Germpeel)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Germpeel &raquo;</TD></TR><TR><TD CLASS="quote">i thought there was no bumping allowed.. other then that, use a volt-ohm meter and check ur wires</TD></TR></TABLE>
yeah thats a good idea! also where exactly are the fuses located? i dont have a map to tell me...
josh0407
Aug 22, 2007 01:19 PM
choua01
Jul 10, 2006 01:18 PM
19codyscivic94
Audio / Security / Video
Dec 19, 2005 04:57 PM
thinknology
Mar 31, 2005 08:58 PM
GSlowR
12
Oct 5, 2002 07:14 PM
