wiring plx300 wideband to ecu
Old Aug 24, 2005 | 01:51 PM
5thGenFanatic's Avatar
Default wiring plx300 wideband to ecu
hi i did a b-swap into my 92 4 door civic and bought the plx300 wideband a/f monitor... i just wanted to know if anyone could tell me where to wire the gray and white wires to the ecm so i can replace my stock o2 sensor.. or send me a link to the entire procedure...the instructions included were 1 paper and they suck... thanks
Old Aug 24, 2005 | 02:01 PM
LSTEG96's Avatar
Default Re: wiring plx300 wideband to ecu (jdmspecb18)
go to http://www.plxdevices.com or check out the instructions on hondata.
Old Aug 25, 2005 | 03:38 AM
Default Re: wiring plx300 wideband to ecu (LSTEG96)
im not using a hondata.. im using the stock ecu.. i looked at them yesterday and it didnt seem to be right..i could be wrong but isnt the wiring different when u use hondata?
Old Aug 25, 2005 | 04:08 AM
Jwbetley's Avatar
If your running closed loop, (still maintaining the stock O2 sensor), than your going to need to weld another o2 bunge on your downpipe. You cant use that one o2 sensor for both your stock ecu and you widband, it will not be accurate. The whit wire, i believe is for datalogging. Let that hang for a while but keep it accessible. The grey wire is for your autometer or regular a/f gauge. You need to weld another bunge for your wideband o2 sensor if your running closed loop. Just run open loop with a basemap and you should be set using only your wideband and a good street tune
my 02
good luck
Treyschls
Dec 11, 2014 07:49 PM
949
21
Jan 3, 2011 06:40 AM
dez6
Engine Management and Tuning
11
Sep 16, 2010 07:17 PM
DCxMagus
Aug 22, 2007 02:45 PM
DaiJekBok
May 24, 2007 08:51 PM
