Brake swap
Old Aug 24, 2005 | 06:09 AM
Cornercarver78's Avatar
Default Brake swap
Hi, I'm not a new member, just havent been here in a while and lost my login. Anyways, I've got a '91 crx that I put integra brakes on and I need to order new tie rod ends. So my question is should i order the tie rod ends for an integra or a crx. Thanks
Old Aug 24, 2005 | 06:16 AM
drdisco69's Avatar
Default Re: Brake swap (Cornercarver78)
I would say CRX, although they could wind up being the same. They'll bolt into the knuckle (assuming you swapped that) just like the old one did.
Old Aug 24, 2005 | 07:56 AM
Default Re: Brake swap (drdisco69)
Yes, I swapped The knuckle, but have a CRX rack and inner tie rod end. Anyone know for sure, thanks
Old Aug 24, 2005 | 08:24 AM
PLEASE!
Old Aug 24, 2005 | 09:31 AM
fujii13's Avatar
Default Re: (Cornercarver78)
well if the CRX one worked, go with that to be safe.
Old Aug 24, 2005 | 03:58 PM
DpSyChO's Avatar
Default Re: (fujii13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fujii13 &raquo;</TD></TR><TR><TD CLASS="quote">well if the CRX one worked, go with that to be safe.</TD></TR></TABLE>
as spock used to say on Star Trek "that is the only logical solution"
eroxer
Sep 13, 2007 10:03 AM
02_IT-S
Suspension & Brakes
Oct 3, 2005 02:06 PM
red civic standard
Oct 21, 2002 11:25 AM
