Wideband o2 location question for tuning...
Old Aug 24, 2005 | 03:30 AM
Takumi Fujiwara's Avatar
Default Wideband o2 location question for tuning...
My hytech header has an O2 bung before the collector, where 2 pipes of only 2 cylinders merge...
I had an extra o2 bung welded on before the cat just after the header collector.
Does is matter which O2 bung is used for the wideband for tuning? Will it give me different readings depending on which O2 bung I use?
Old Aug 24, 2005 | 07:07 AM
jmcclell's Avatar
Default Re: Wideband o2 location question for tuning... (Takumi Fujiwara)
It's best to place the sensor on or after the header collector. You need to get an average reading of all 4 cylinders as there will be a difference with each cylinder pair due to a small variance of its air flow characteristics, volume and injector flow rate.
No two cylinders are the same
Old Aug 24, 2005 | 08:10 AM
Default Re: Wideband o2 location question for tuning... (jmcclell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmcclell &raquo;</TD></TR><TR><TD CLASS="quote">It's best to place the sensor on or after the header collector. You need to get an average reading of all 4 cylinders as there will be a difference with each cylinder pair due to a small variance of its air flow characteristics, volume and injector flow rate.
No two cylinders are the same </TD></TR></TABLE>
Not just an answer, but an explanation too... thanks!
project93accord
Feb 3, 2006 05:42 AM
Gump
Jul 26, 2004 08:45 AM
YEE*MagicEK20kombobomber
Feb 29, 2004 08:04 PM
Griffins_Importuning
Aug 4, 2002 01:15 AM
Black R
Feb 12, 2002 04:38 PM
