'86 Accord EX losing power(Electricity)
Old Aug 24, 2005 | 03:21 AM
ekntra's Avatar
Default '86 Accord EX losing power(Electricity)
HI!
I have a problem with my power supply.
2 weeks ago everything was working perfect, i turned the volume on my stereo up to 35 and the battery never got empty, i have 2x 12" pioneer subs 760watts amp.
just changed dynamo it charges 14,3V and new 60AH battery
problems: it seems that the battery is constantly losing power i cant play the stereo now at more than 7 unless i wanna see the charging lamp in the dash flash along as the subs beat, the horn is not working anymore and the driving lights wont turn on as normal so i have to turn on the light switch to get lights, all the lightbulbs are working - fuses have been checked over and over seems to be working
Old Aug 24, 2005 | 03:55 AM
Vanilla Sky's Avatar
check your fuses, your battery, your battery connections, all of your grounds, and your alternator. have the charging system tested at an autozone or checkers/kragen/advance.
Old Aug 24, 2005 | 04:30 AM
P_Adams's Avatar
Default Re: (Vanilla Sky)
I seriously doubt that there's an AutoZone in Norway, Vanilla.
But I do suspect a POSSIBLE problem with his dynamo (alternator to us colonists). He may be seeing reduced output.
On your sound system... I've noticed that some of the large(er) systems that they incorporate large capacitors to drive the base speakers as a way of buffering the power spikes (which you state you're seeing indications of.
Just a thought
P
Modified by P_Adams at 1:41 PM 8/24/2005
Old Aug 24, 2005 | 05:40 AM
JimBlake's Avatar
Default Re: (P_Adams)
On newer Hondas (here anyway) there's a wire labeled "C" on the alternator. The ECU can bring that to ground when it wants to shut off the alternator. If that wire is rubbed bare & shorting to ground, that'll also shut down the alternator.
Trouble is, I don't know what year Honda started doing that, & I don't know whether it's wired the same in Norway... If your alternator has a 'C' wire, check it out.
Old Aug 24, 2005 | 07:38 PM
didn't look at the location, man, hehe.
Old Aug 24, 2005 | 07:44 PM
P_Adams's Avatar
I hear you Floridians may be in for some real estate rearranging. Hope you're out of the way....
P
BiG_DeE88
May 18, 2010 12:25 AM
wood181
Apr 15, 2008 06:59 PM
Mr.Speed
Dec 8, 2006 11:43 AM
Jetblade
Feb 21, 2006 01:33 PM
skiracer8148
Jan 4, 2006 09:00 AM
