Just installed my new Lightweight Odessey Battery.... whats next ?
Old Aug 23, 2005 | 11:07 PM
ApolloSpeed's Avatar
Default Just installed my new Lightweight Odessey Battery.... whats next ?
Just installed a Oddesey PC680 13.5lb battery (my stock battery was 28 lbs)....... Awesome !! I Love It !! Starts up like a charm. Only 75 bucks.
Also, I fabricated an aluminum top bracket to fit it better.......
And, I just finished painting my Valve Cover.
And installed N1 Muffler, and test pipe and fuel pressure gauge.
--Next Should I--
1. OBX Header = $150
2. Clutch and Light Flywheel = $325
3. 16" Rota Slipstreams = $460
4. New o2 Sensor =$100+?
5. A/F ratio and oil psi gauge =$200+
6. New Slotted rotors/ Pads =$200
7. ECU chip or Vtech controller =$100+
I plan to get all soon or later......just not sure whats next....
Old Aug 23, 2005 | 11:30 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Just installed my new Lightweight Odessey Battery.... whats next ? (ApolloSpeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ApolloSpeed &raquo;</TD></TR><TR><TD CLASS="quote">Just installed a Oddesey PC680 13.5lb battery (my stock battery was 28 lbs)....... Awesome !! I Love It !! Starts up like a charm. Only 75 bucks.
--Next Should I--
1. An OBX Header is a waste of money. Don't buy it. Ever.
2. If you need a clutch, get this next
3. Rims are always good, but make the car run right first
4. o2 sensor should only be replaced if your sure its fucked... is it?
5. An Air/Fuel Gauge is Worthless unless your running a Wideband O2, oil press is good to know though
6. Brakes are always good... new blanks and good pads.
7. Dont do a VTEC Controller.. I hate those things. Chip your stock ECU and use Crome or Uberdata or something of the sort... but being stock, you dont really need either. ECU should be one of the LAST things you do.
Good luck!
Old Aug 24, 2005 | 02:42 AM
WayQuiz's Avatar
Default Re: Just installed my new Lightweight Odessey Battery.... whats next ? (JDM_Ej)
where did you buy the odessey battery from?
Old Aug 24, 2005 | 07:36 AM
egyolk's Avatar
16 slips are huge for the del y0 15's @ most, IMHO
Old Aug 24, 2005 | 07:53 AM
Default Re: Just installed my new Lightweight Odessey Battery.... whats next ? (oversteerINGS)
Battery was an ebay special....
So, yall don't recommend the OBX header ? What is a good header ?
Also, should I get a turbo header and just block it off until I get turboed ????
yet, it may be a while til I get turboed.
A/F ratio should work shouldn't it
also, can someone recommend a good mild peformance chip ?
crxma22
Honda Motorcycles
15
Dec 9, 2006 12:53 PM
Voodooboy520
Feb 28, 2006 03:49 PM
RGoose18
May 23, 2005 05:47 AM
TIRENECK
Dec 14, 2003 10:29 AM
ITRJunkie
Audio / Security / Video
13
Aug 6, 2003 05:59 AM
