New coil and icm... rpm jumping at 7k STILL !!!
Old Aug 23, 2005 | 10:42 PM
X2BOARD's Avatar
Default New coil and icm... rpm jumping at 7k STILL !!!
FRAK !!!
I had some issues a while ago... I narrowed it down to having a bad coil. I replaced it with a brand spankin new MSD Blaster 3 SS Coil (looks like a house). As a precaution, I also replaced the ICM with a brand new ICM (not OEM).
I still have the original cap and rotor which didn't look bad and have about 35k miles on em.
The car now pulls fine... but at 7k... the tach jumps wildly to 8k+ and the engine kinda skips a beat when it happens. Prior to the new icm and coil... it would stutter at many points in the rpm band... but now with the new parts... it's only happening at 7k... pulls fine till then.
So WTF now ? Tach signal ? All the dizzy wires looked fine. Mag Pickup ? Help ?
Old Aug 24, 2005 | 05:50 AM
X2BOARD's Avatar
anyone plz !
Old Aug 24, 2005 | 01:44 PM
X2BOARD's Avatar
Default Re: (X2BOARD)
Could a weak or dead battery cause this ?
Old Aug 25, 2005 | 08:15 AM
X2BOARD's Avatar
weak battery anyone ?
Old Aug 25, 2005 | 09:20 AM
PURPLETERROR aka BIGMATT's Avatar
Default Re: New coil and icm... rpm jumping at 7k STILL !!! (X2BOARD)
clean and tighten the connections to the icm
Old Aug 26, 2005 | 08:55 AM
boomslang's Avatar
Default Re: New coil and icm... rpm jumping at 7k STILL !!! (PURPLETERROR)
The distributor assembly could be bad. I just went through the same thing a few months back with my ITR swap.
I tried 3 different ICMs. 1 used and 2 new ones. It would work for a while then the ICM would die.
Does your distributor have red dust inside the cap? Mine did, a sign of bearing failure.
The only thing that fixed my problem was a new distributor assembly.
Old Aug 26, 2005 | 11:54 AM
X2BOARD's Avatar
fak... no red stuff.
But I just found out BOTH my battery AND alternator are kaput...
I am replacing both and I'll update after...
byc_cb7
Aug 28, 2009 10:15 AM
MumBleZ_94gsR
Jul 28, 2009 04:53 PM
DOHCarp
Jun 13, 2007 09:28 AM
96b18c
Oct 8, 2004 11:45 PM
jmk2888
15
Sep 5, 2004 05:19 AM
