Getting Fed the F*** Up with My Integra
Old Aug 23, 2005 | 08:31 PM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
Default Getting Fed the F*** Up with My Integra
Ok, so I bought my integra like a week ago now. It was cool at first, then I saw that someone ripped the pins out of the O2 sensor. Now my oilpan leaks like a ******* faucet. I changed the oil pan gasket twice now, still leaks even using a gasket sealer (2x). I am seriously sick of this crap. Why is it leaking even though there is a new gasket? I just wanna throw it off a cliff. /rant
Old Aug 23, 2005 | 08:35 PM
Johnny Gasparini's Avatar
I didn't ask for a dime.
Default Re: Getting Fed the F*** Up with My Integra (ahrpr)
Have you located exactly where the leak is coming from. It might not be a gasket leak. It may be the pan itself.
Old Aug 23, 2005 | 08:36 PM
Default Re: Getting Fed the F*** Up with My Integra (Rebel Scum)
Well, it seems to be coming through the bolts themselves which i thought was odd or you know where the bolts go there is that piece of metal protruding off of the pan? Im thinking the damn pan is bad, any idea where to get a new one for cheap?
Old Aug 23, 2005 | 08:41 PM
Try the junkyards first. If you are not able to find one try the classified forum here. If you still can't find one, check Ebay.
Old Aug 23, 2005 | 08:42 PM
I don't think my pan is bad theres no cracks, cuts in it I don't understand how it went bad unless theres a bad weld or something.
Old Aug 23, 2005 | 08:57 PM
pat.ter.rick's Avatar
bring it to a mechanic.
Old Aug 24, 2005 | 10:05 AM
EG_H2B's Avatar
Default Re: Getting Fed the F*** Up with My Integra (iownzadc2)
steam clean it so that everything is clean and you will be able to locate exactly where it is comming from
Old Aug 24, 2005 | 10:08 AM
downeyballz's Avatar
Default Re: Getting Fed the F*** Up with My Integra (JohnShiwota)
are the bolt holes stripped on the bolck, preventing it from getting a tight seal
Old Aug 24, 2005 | 10:12 AM
Ekay Jay's Avatar
Were u torqing the pan down to the right specs?
Old Aug 24, 2005 | 10:22 AM
5 Speed AP2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnShiwota &raquo;</TD></TR><TR><TD CLASS="quote">steam clean it so that everything is clean and you will be able to locate exactly where it is comming from</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by downeyballz &raquo;</TD></TR><TR><TD CLASS="quote">are the bolt holes stripped on the bolck, preventing it from getting a tight seal</TD></TR></TABLE>
Troubleshooting sucks, but theres nothing like the feeling of finally defeating the problem.
Old Aug 24, 2005 | 10:47 AM
Racermech's Avatar
Default Re: Getting Fed the F*** Up with My Integra (5 Speed Dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JdM DA InTeGrA &raquo;</TD></TR><TR><TD CLASS="quote">Were u torqing the pan down to the right specs?</TD></TR></TABLE> and the correct sequence?? you cant just tighten the bolts down and hope for the best
Old Aug 24, 2005 | 10:51 AM
Jeff_B's Avatar
Default Re: Getting Fed the F*** Up with My Integra (Racermech)
The torque spec is 9 ft/lb and there is a specific tightening sequence. Not following it or overtorquing can cause the gasket to distort and leak.
Old Aug 24, 2005 | 11:00 AM
intgrboy's Avatar
Default Re: Getting Fed the F*** Up with My Integra (ChassisInnovations)
You shouldn't have to use sealant either - just make sure the seating surface of the pan is absolutely clean and oil free and torque those bolts properly.
Old Aug 24, 2005 | 11:13 AM
jay_c's Avatar
Default Re: Getting Fed the F*** Up with My Integra (intgrboy)
A little honda-bond always helps.
Old Aug 24, 2005 | 12:04 PM
Dunc's Avatar
BCICAN
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ChassisInnovations &raquo;</TD></TR><TR><TD CLASS="quote">The torque spec is 9 ft/lb and there is a specific tightening sequence. Not following it or overtorquing can cause the gasket to distort and leak.</TD></TR></TABLE>
What is the sequence?
Old Aug 24, 2005 | 01:54 PM
txracer's Avatar
Default Re: Getting Fed the F*** Up with My Integra (Dunc)
could the pan be warped maybe, dont see how it could happen if it was bolted to the car but maybe the last guy took it off and it got bent.. prolly not but wouldnt hurt to check
Old Aug 24, 2005 | 06:06 PM
can I use a GSR oil pan or Type R oil pan?
Old Aug 24, 2005 | 07:40 PM
b00sted4dr's Avatar
WHere did you buy the gasket from?
Old Aug 24, 2005 | 07:59 PM
Default Re: Getting Fed the F*** Up with My Integra (b00sted4dr)
o' reillys
Rubber gasket (blue)
Old Aug 24, 2005 | 08:11 PM
Racermech's Avatar
get an oem gasket, do some searching around, or get a helms. Find the correct TQ and sequence.
Clean the pan and the block very well. Take you time and i bet everything will work out just fine
Old Aug 24, 2005 | 08:35 PM
thanks a lot for your help guys. yeah the block & pan are all gunked up with silicone and junk.
Old Aug 24, 2005 | 10:34 PM
greentegsandspam's Avatar
check if the bolts are specifically for the oil pan as well. I had the same problem and bought a new oil pan and replaced about 6 oil pan bolts. I bought the car used and found out that the used the wrong bolts. The bolts were diferent lengths and just did not look like the others.
Old Aug 25, 2005 | 04:23 AM
b00sted4dr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahrpr &raquo;</TD></TR><TR><TD CLASS="quote">o' reillys
Rubber gasket (blue)</TD></TR></TABLE>
Exact thing happened to me bro. I used the blue o'reillys and it leaked everywhere. I went out and bought an oem one from honda, never leaked again.
for oem
Old Aug 25, 2005 | 06:17 AM
jsnm's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00sted4dr &raquo;</TD></TR><TR><TD CLASS="quote">
for oem</TD></TR></TABLE>
same here,except i used a blue fel-pro one three different times,they seem really week and soft,leaked like a ****,the oem ones are the best.
Old Aug 25, 2005 | 09:44 AM
Default Re: Getting Fed the F*** Up with My Integra (jsnm)
******* awesome guys, thanks for comin together and helpin me out, yeah ive went through 3, **** o-reillys fel-pro.
